eta stroker, non turbo
  • megadangerous18
    • Sep 2014
    • 2
    I am currently working on collecting parts for my '86 325e to become a stroker (non-turbo). The only question I have is can I to raise the compression back up to 9:1 or better just shave some of the 325i head? If so how much would I need to? And would I still have enough clearance for the valves and pistons to not touch? If anyone knows or at least has an opinion that would be awesome. Also keep in mind I don't want to buy custom pistons.
  • Cabriolet
    • 9620
    Here are 2 things you need to look at before messing up your head.
    BUILDING A 2.7
    The 2.7 ETA ENGINE
    These arrived in 1983 to power the 525e and 325e (not UK) although the US had them in 1982 for the 528e.
    Eta is the Greek symbol for efficiency and it is a low revving engine rich in low speed torque but low on power. It does not rev much past 4500 and uses an 84mm bore and an 81mm stroke crank to give 2693cc. The crank is made from spheroidal grey cast iron and the connecting rods are the same 130mm end-to-end items as the 320, 320i, 520, 520i and 323i.
    The cylinder head is derived from the E21 320/323i and E12 520 small port head known as the 200 from its casting number. It has a special four bearing cam designed for low speed torque and it is useless. Throw the entire Eta head in a skip, it is of no use at all for a performance application. The same goes for the inlet manifold and throttle body, injectors, ECU and AFM. You just need are the block, crank, rods and possibly pistons (more of pistons later).
    Early Eta's up until Sept. 1985 had a compression ratio of 11:1. The blocks of these engines is stamped 27 6KA. From 9/86 the compression ratio was dropped to 10.2:1 and these engines are stamped 27 6EB. These numbers are stamped above the main engine number. BMW dropped the CR due to detonation issues on 95RON - no knock sensors back then!
    To build a 2.7 you have three options:
    Retain the standard Eta bottom end untouched and fit a head from an E30 320i or 323i. This is the 731 head which has much bigger inlet ports than the 200/Eta. It has the same sized valves as the Eta which are 40mm inlet and 34mm exhaust. The combustion chambers are identical the Eta 200 head so by fitting a 731 head, you will retain the Eta compression ratio.
    From here you can open up the tops of the inlet ports using a 325i inlet manifold gasket as a template to accept a 325i inlet manifold, or you can use the 320i/323i manifold with or without a 325i throttle body. It will be a bit flat at the top end without one though. You are not likely to get past 180 bhp but it will be pretty torquey.
    Use the standard Eta bottom end with a 325i head, the 885 unit. The 325i has strange pistons with a deep dish but a raised section at the front of the combustion chamber to accommodate it. Despite what experts say, the 325i head will NOT give a horribly low compression ratio. The difference in chamber volume is quite small. The 325i head has a chamber volume of @ 42.5cc and the 731 and 200 heads have a chamber volume of @38cc. It all depends on whether the head has been skimmed. But 4.5cc difference isn't much at all and much of the increased size of the 325i chamber is made up for by the bigger valves and surrounding raised areas around them. 325i valve sizes are 42mm inlet and 36mm exhaust.
    A lot has been said about Eta pistons being incompatible with the 325i head. Most of it is nonsense as this has been done many times and it works okay. Of course it won't give results quite as good as using the matching 325i pistons but it still has a good compression ratio which is most of the battle won.
    Again, depending on which gasket is used and whether the head has been skimmed, using a 325i head on a later 10.2:1 Eta short engine will give a CR of 9.4:1 which is plenty. If you can even find an early 11:1 Eta engine, the CR would be 10:1 which is even better. Because you are using a 325i head, just bolt a 325i inlet manifold straight on.
    I converted a 1986 525e Auto to this spec and it was very lively - 0-80 in 21 seconds which is just 1 second slower than an auto 528i which has both 184 bhp and a lower final drive. Then I pulled the engine out and it went into an E30 Touring
    Using 325i pistons with a 325i head. This is the best way of doing it but requires a complete engine strip down.
    Doing this, the pistons of course match the head. Compression ratios will be 9.4:1 using post 9/87 (plastic bumper) 8.8:1 CR pistons and 10.4:1 using the early pre 9/87 (steel bumper) 9.75:1 CR pistons. Why the higher CR in a 2.7? Because it has an extra 49.8cc of fuel/air mixture to compress.
    To keep the con rod angle correct, BMW made the 325i conrods 5mm longer. So if you fitted a 2.7 81mm crank into a 325i block (basically the same as the Eta block), the pistons would stick out of the top of the bore by 3mm. To get around this, you need to use 130mm Eta/2 litre rods. Then the pistons don't come to the top of the bore - about 2mm short in fact. It is no good guessing how much to take off the block face because early Eta blocks were very slightly taller (we are talking half a mm maybe) so you need to fit a 325i piston and 130mm rod to the Eta crank and block, take it to a machine shop and get it measured up properly to get an exact figure. It will not cost any more, and it will be bang on.
    1.5 - 2mm is just a ballpark figure.
    The next problem is that with @2mm off the block, the crank and the cam are now 2mm closer together which will mean the cam timing will be wrong. For this you will need a vernier (adjustable) cam pulley to adjust the cam timing, particularly if you are using an aftermarket cam. Early 325i pistons (9.75:1) have deep skirts and need 12mm machining off the skirts because they will foul the Eta crank webs. Later pistons clear fine though.
    There is another alternative if you have a "super eta" (which is a 1988 325, badged 325 on the trunk and says 325e 10/87 or later on the sticker in the door)
    This is probably the easiest route to go as few parts are needed. The parts listed here are the ONLY parts needed.
    325i cam 325i fuel injectors, rail, and pressure regulator 325i valve springs 325i intake manifold 325i throttle body with throttle position sensor 325i idle control valve 325i air flow meter 325i intake boot 325i ECU
    The "super eta" already has the proper head with all 7 oil journals, it just needs the stiff valve springs to prevent horrible valve float and/or valvetrain damage, and the cam. It also already has the i wiring harness and most of the same electrical components, as well as the dual exhaust. You will also need the various gaskets and head bolts associated with a normal rebuild. The "super eta" has a 6k tachometer, which will read fine until it nears 6k which it will just stop until the revs return to under 6k.
    Other stuff:
    ECU etc
    You will need a complete 325i Motronic set up. ECU, inlet manifold with injectors, air flow meter. Good news if you already have a 325i.
    The ECU will need remapping. A 2.7 engine will have faster piston speed meaning it will get to the top of the bore and point of ignition faster - over a 325i, the piston has an extra 6mm to travel in the same amount of time (one crank revolution), requiring a change in ignition timing. Also, the long stroke increases the piston dwell at TDC. It will need more fuelling too.
    Head Gasket
    Eta and 325i are the same. You can buy standard or thicker gaskets which will lower the compression.
    Radiator
    Is the standard 325i radiator okay? Yes, it's fine.
    Spark Plugs
    Which spark plugs? Bosch W7DCR or the NGK equivalent. The plastic bumper 325i uses W8€ plugs which are not quite right for a 2.7. 2.7 engines have higher compressions and higher compression ratios equal more heat, and you need a plug to dissipate the heat faster. The W7 is known to work.
    Crank
    UK 525e cars were autos and you need to fit a spigot bearing in the flywheel end of the crank.
    How to tell an Eta crank from a steel diesel crank? Eta cranks will have either GG or GGG cast into a web meaning cast iron. Both will have Hub.81 cast in denoting the stroke. 81 is Eta/diesel, 75 is 325i, 66 is 2 litre and 76.8 is 323i.
    Cylinder Heads
    731 or Eta heads do not work with 325i pistons because the raised crown would smack into the head and lock it up.
    Sump
    The E30 sump fits straight to an Eta block but you need 25 longer bolts because an alloy sump is thicker than a pressed steel one. The BMW part number is 07119915031.
    Eta steel sumps will not fit an E30. The bulge is too long and will foul the rack.
    TDC Sensor
    Eta blocks have the two threaded holes to take the later Motronic front TDC sensor.
    Cams
    Be careful with your choice of cam. Wild 285 degree cams probably won't pass the hydrocarbons test.
    This is an idiots nuts and bolts guide to building a 2.7 litre engine. Please don't bombard me with P.Ms as just about everything is here to put the engine together. This is not rocket science, just simple nuts and bolts. All the compression ratios are worked out for you.
    As for further tuning (cams, remapping etc), I will leave that to those better qualified!
    Much wow
    I hate 4 doors
    • Steve Corbett
      • Jul 2012
      • 449
      BUILDING A 2.7
      The 2.7 ETA ENGINE
      Are you sure about that compression ratio? Bentley lists it at 9:1 and 8.5:1
      Steve Corbett
      1983 528E Scrapped
      1983 528E Sold
      1984 745I
      1984 325E - Sold
      1989 325I Bronzit-Sold
      1989 325I Zinno
      1988 635CSI
      • digger
        • Nov 2005
        • 6178
        most will probably be the 9:1 versions or 8.5 for the SETA.
        you can take more material off the head to regain some lost compression if swapping to the bigger chamber 885 head or user a thinner custom gasket $$$, but half a point extra is not going to be very noticeable.
        ive no idea what the piston to valve limitations are with the ETA piston i threw the last set i had out.
        • 4x4_e30
          • Sep 2013
          • 164
          I don't understand, that quote contradicts your point.
          Shaven 885 Head on ETA Bottom = 9:1 C/R Has anyone actually CC'd their own head?
          • megadangerous18
            • Sep 2014
            • 2
            Thank you for the info, I think I'll just leave the 885 head alone and cause i'm pretty happy with the 9.4:1 c/r the only other thing is has anyone done a remap for this? Or know of someone who has?
