Originally posted by Insanity
Help Me Build the Ultimate HEAD!!!
Well 14,000 is a bit extreme - I was aiming more for 5000 to 7000 since its a track car...Driving is the only way to go faster.... -
verrry true! i can empasize with your time constraints believe my (8-5:30 m-f & 8-3AMish? fri and sat nights, doesn't leave alot of extra time for the car) i've done P&P for a long time; but, i was taught by some very knowledgable and experienced people (thanks dean lowery!). i have seen some seriously bad head work. to be able to make the statement that a head can/ will preform at a certain RPM can only accurately be made from experience with many heads and knowing where to remove material to increase the RPM/powerband. it's not just make the ports bigger and you will get more power up high. big ass hole=lower velocity in the port= no power down low= you may never get the motor up to that desired RPM:( . if you have a shop do the P&P ask them to just match the ports to the gaskets or slightly bigger. don't try to reinvent the wheel. have that and what i suggested earlier done to the head you should have nice power and be reliable. i don't know what the valve life expectancy is on m-20's, but any rebuilder worth a shit will know if you can rebuild the head w or w/o buying new valves and they should inspect them anyways. stainless steel valves may also be a good alternative for you. they are USUALLY cheeper and lighter than stock. reliability shouldn't be an issue for you as long as they are from a good manufacturer (i have always had good luck with Manley). as for the TI retainers, yea they aren't the greatest for a DD (since TI doesn't seem to like heat cycling in an engine, that's what makes it brittle/crack), but i have also used them on street with no problems (in air and water cooled VW's and flat-six porsches). i did pay attention to them and check them because i knew of the possable problems.Originally posted by InsanityThe point is that people don't understand that the difference between 5000 and 14,000 is a very minimal amount of material.
hope this helps,
gregseien Sie größer, als Sie erscheinen
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
