O2 sensor
  • kbaszak
    • Sep 2013
    • 66
    O2 sensor
    Replacing my o2 sensor, I read that you can use a mustang sensor just have to splice into the old connector. Which mustang o2 sensor should I buy? The current one on my car is 4 wire but from what I've read you're supposed to use the v8 mustang sensor and those are 3 wire? At least the ones the part store showed me were. Unless they were retarded and were giving me the wrong year. Can someone help a brother out here
  • dnguyen1963
    • Nov 2011
    • 2649
    Why don't you get the correct one from Blunt?
    • kbaszak
      • Sep 2013
      • 66
      Because I'd rather have my car back on the road today for ~$40
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        You don't need one to drive? Order one from blunt and drive it how it is until then
        1991 318i 4dr slick top
        Mtech 2 turbo restoration
        • kbaszak
          • Sep 2013
          • 66
          I really don't want to spend probably $150 when I can have something that does the same thing for a lot less
          Edit: Also, I'm not going to be keeping the current engine that is in the car for more than probably 6-8 months so I'm trying to keep maintenance costs down during that time
          • dnguyen1963
            • Nov 2011
            • 2649
            It's worth the money to get the correct one for the car. It's less than $100.
            But if you are not going to keep the engine then why bother with replacing it. Are you coming up for an emission test?
            • kbaszak
              • Sep 2013
              • 66
              Yea, a couple weeks from now
              • dnguyen1963
                • Nov 2011
                • 2649
                Well, think about it...$40 for a sensor that might not work or $100 for a much better chance of passing smog.
                • Andy.B
                  • Sep 2011
                  • 1650
                  I've used the universal replacement sensors countless times on my own and customers cars and never had a problem. Some Google-fu and you can find some of the many part numbers that interchange.
                  • JasonC
                    Site Manager
                    • 14451
                    The Mustang sensor DOES work. I just put one on my car not to long ago. I think I got one for a 90 Mustang with a 302. It was a 3 wire where the e30 is 4. You match the wire colors, and the one left over on the e30 side you have to ground it to the chassis.
                    1992 BMW 325iC
                    1978 Chevrolet Monte Carlo
                    • kbaszak
                      • Sep 2013
                      • 66
                      Gotcha, thanks
                      • g.ruff561
                        • 1265
                        Any part number on that 02 sensor would be appreciated. I have found 3 at Advance Auto Parts. All 3 are 4 wire.
                        Thanks. ........ G.
                        • g.ruff561
                          • 1265
                          Up..............
