No start: fuel issue
  • spdracrm3
    • Sep 2009
    • 959
    the OBC has a security code option that controls a relay in the box above the ABS controller and depending on model it either controls power to coil or a power signal to ECU or power to main relay (if a code is set this relay will not power up one of these and car will not start ) but we have seen the relays fail on the OBC relay box causing various not start issues .
    from the ETM for your car it appears to control the the main relay (page 110) (you mentioned testing a relay for power but never said which one) ,so if you have power at 86 pin of main relay this is not your issue assuming ETM is also correct....
    sounds like you have an aftermarket alarm installed and this could be causing your no start as who knows hows it wired in ,i would look at removing it to eliminate it as a possible cause of no start
    Angus
    88 E30M3 X2
    89 325IX
    92 R100GS/PD
    • 416stroker
      • May 2008
      • 2448
      Also you can bypass the OBC relay pretty easy won't hurt anything. When I trouble shot mine I was able to test it with jumper wires.
      84 318I Delphin RIP
      87 325IS delphin 24v Sold
      89 325 Alpineweiss
      • HennaE30
        • Apr 2014
        • 1965
        I caved and took it up to Spec Motorsport. I just don't have time to keep farting around with it
        Originally posted by flyboyx
        how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
        Originally posted by Northern
        beer is my new liver cleanse.
        Henna - '84 Hennarot 325e
        Lola - '89 Schwarz 325is - being saved
        Christine - '88 Schwarz 325is - Spec E30 Racecar
        '01 White F150 Lariat 4x4 Supercrew - Daily
        Dad's '05 Interlagosblau M3
