Cold start RICH mixture
  • digger
    • Nov 2005
    • 6216
    could be a overall fuel issue that the O2 sensor is masking once it comes online (i.e. o2 only helps when warm/hot).
    if everything checks out i would test another ECU as its relatively simple/cheap
    how did it drive before the rebuild?
    • snaponbob
      • Oct 2014
      • 34
      Good thoughts. Will do.
      • snaponbob
        • Oct 2014
        • 34
        Weeeeeeellllllllllllll !!!!!!!!!!!!!!!!!!! So after looking at the data stream on my SnapOn scanner, I found that the TPS was NOT indicating Throttle Closed at idle. Addressed THAT, and presto. Just the "normal" M20 cold start rich. But, starting properly, idling properly, and so on.
        • digger
          • Nov 2005
          • 6216
          interesting that the TPS didnt show symptoms when hot/warm.....
          • snaponbob
            • Oct 2014
            • 34
            Once it warmed up, it was still (smelling) rich. FIRST time I had to deal with this sort of thing .... and I have dealt with a few !! Anyway, I think I need to replace the TPS, because at this point I do not trust it. Certainly it needs adjustment as there seems to be an off idle hesitation. Plenty of time, so no worries.
            • snaponbob
              • Oct 2014
              • 34
              Probably because the computer was in closed loop and the O2 takes over.
