euro spec m20 B25 HP difference
  • Shftr8
    • Aug 2014
    • 530
    Does anyone know a close estimate on the HP number on a euro spec M20 compared to a US spec one? Cant find a very good answer. Also is there a market for the engine here in the states or is not worth someones time and effort?
  • LJ851
    • 7919
    There is no difference.
    What sort of aftermarket are you looking for?
    Lorin
    The M30 is God's engine.
      • 37833
      Some Euro 2.5L cars had higher compression pistons. Not all though.
      Grover Beach, California
      BimmerHeads.com
      • downforce22
        • Aug 2009
        • 3192
        The high compression engines were rated at 1 higher hp and a couple more pounds of torque but it was at a lower rpm I believe.
        They say 1 point of compression is a 3% increase in power so US m20 8.8:1 and Europe 9.7:1 is a hair under 3% additional power. Maybe noticeable but not much difference
        • meengreene30
          • Mar 2012
          • 369
          I'm more than satisfied with my cam'd and ported 731 head build, if that's what you're referring to. If you have the dogleg trans, i bet alot of people would be interested in that.
          • meengreene30
            • Mar 2012
            • 369
            Plus the b23 had aluminum motor mount arms, the 2 piece trans housing, lightened flywheel, better looking valve cover(imo). Yea you'd be able to sell it.
            • Shftr8
              • Aug 2014
              • 530
              Looking to go s52 and just wanted to know if this motor is worth something or worth holding onto for another project
