E30 problem please help
  • hakop_e30
    • May 2014
    • 90
    Please help I don't know why it's doing this? Heres a video https://m.youtube.com/watch?v=b70UBE3vV5c
    1989 BMW 325I Mtech 2
  • hakop_e30
    • May 2014
    • 90
    The check engine keeps going on and off
    • mazzo
      • Jul 2014
      • 264
      Can you pull the code out?
      Current:
      '88 325ic Silver 5sp
      '17 Subaru Outback 3.6R
      Past:
      '14 Rav4 EV (with tons of torque!)
      '06 325i Black 5sp
      '02 S4 Avant Black 6sp
      '00 Boxster Silver 5sp
      '98 New Bettle Yellow 5sp
      • hakop_e30
        • May 2014
        • 90
        for some odd reason when i do the stomp test my check engine doesn't flash a code
        • mpowerful
          • Jul 2013
          • 1273
          Does it even try to flash when you stomp test it? Ie is it giving you no code code? If not you may not be stomping it right.
          • meengreene30
            • Mar 2012
            • 369
            If your TPS is bad the stomp test won't work. Unplug your tps see if that makes a difference.
            • hakop_e30
              • May 2014
              • 90
              whars tps lol sorry a noobie
              • Lugnuts
                • Oct 2014
                • 136
                Throttle Position Sensor.
                Number 24:
                http://realoem.com/bmw/showparts.do?...34&hg=13&fg=15
                • E30NJ
                  • Aug 2013
                  • 921
                  Any update?
                  • hakop_e30
                    • May 2014
                    • 90
                    https://m.youtube.com/watch?v=31dh5cmTAII This is another video
                    • hakop_e30
                      • May 2014
                      • 90
                      Bump
                      • crappycoco
                        • May 2014
                        • 250
                        Looks like this:
                        you can probably read the comments from here on =)
                        • hakop_e30
                          • May 2014
                          • 90
                          https://m.youtube.com/watch?v=rfXRZJUY8R4 Do you think it might be from this
                          • crappycoco
                            • May 2014
                            • 250
                            Take some ATP and seal that. Check the other side too. Those are vacuum leaks 100%. Not sure if that's whats causing your car to behave like that tho.
                            • Lugnuts
                              • Oct 2014
                              • 136
                              I have the same fitment issue on the right-hand side of my TB - the links to the brake master cylinder. They're not quite as loose as yours, but they're easy enough to pull out. Just slap some RTV gasket sealer in there.
