1986 325ES Getting it running
  • dprussky
    • Dec 2014
    • 25
    I just picked up 325ES and running into the trouble identifying the parts/sensors that are missing or wrong. I suspect previous owner try to use 325i parts, but run into the problems. There is one connector that appears does not have home…. but it is clearly 325E
    1986 325ES
    Build progress recorded here
    https://www.facebook.com/BMW325ES?ref=hl
  • 101
    • Jul 2011
    • 764
    My eta is stored currently so I'm going on memory.
    As I recall there is an air temperature sensor on the engine side of the air filter box. That cable you are highlighting in the first picture should wrap around the front of the air filter box and plugs into that sensor. The eta's idle control system uses that as an input. There is no separate air temperature sensor on the "I" cars.
    If your previous owner left you with an "I" air filter box that sensor won't be there.
    101
    The E30 collection:
    1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
    1987 325is - Delphin / Black Sport (son #3's)
    1987 325i Convertible - Triple Black
    1989 325iX Coupe - Diamondschwarz / Black Comfort
    1990 325iX Coupe - Sterling Silver / Grey Sport
    1981 Fiat 124 Spider 2000 - Green / Tan
    1998 Volvo V70 GLT - White / Tan
    1998 Volvo S70 T5 manual - White / Taupe
    2001 Ford Windstar - Silver / Grey (parts hauler)
    2006 Lexus GX470 - White / Tan (tow rig)
    • dprussky
      • Dec 2014
      • 25
      Thank you that makes perfect sense. Part number on the Air Flow meter is 0 280 202 066 which is one of the "I"
      1986 325ES
