M20....signature tilt
  • IronFreak
    • Dec 2012
    • 3702
    I'm working on a little project and when I Google pitch or degree of the m20 in the engine bay I get a bunch of bolt and cam threads....
    Can someone quickly tell me how many degrees off vertical 90 the m20 sits in the engine bay?
    Thanks
    Instagram @rebellionforge
  • Ether-D
    • Sep 2011
    • 2838
    Going off of an oil pan, 60 degrees, or 30 off of vertical.
    Originally posted by Andy.B
    I was born on 3/25…
    • Ether-D
      • Sep 2011
      • 2838
      Or were you referring to fore/aft tilt?
      I was born on 3/25…
      • IronFreak
        • Dec 2012
        • 3702
        Vertical left/right (Pass/driver).
        Thanks man, I appreciate it.
        • IronFreak
          • Dec 2012
          • 3702
          you said 30 in here and 20 degrees in the m20 manifold thread?!
          • Ether-D
            • Sep 2011
            • 2838
            Oopsie? I just did it again to re-check myself. I got 30 degrees.
            I set the flat part of the m20 pan on a level surface, then measured the angle of the mating surface.
            I'm assuming two things here. The bottom of an m20 oil pan is level with the ground, and the mating surface is perpendicular to the center line of the engine.
            What I know, is that it can only be one of these numbers. Which one? I'm inclined to think its the 30 degree one because I measured it with my own eyes and hands.
            My guess is that Nando maybe got the numbers backwards? He may not be unflappable after all.
            I was born on 3/25…
            • IronFreak
              • Dec 2012
              • 3702
              Hahaha, I just chuckled when I read that. I'll be dropping in my motor here in the next couple weeks. I'll double check when it's in the car.
              • Ether-D
                • Sep 2011
                • 2838
                So more scouring gets someone saying that the oil pan is 30 degrees and the actual motor is 20 degrees. So center line is not purpledickular. Maybe solved?
                And Nando is still unflappable…
                I was born on 3/25…
                • Ether-D
                  • Sep 2011
                  • 2838
                  Alright. I looked at an m20 block today and the oil pan mating surface and the head mating surface appear to be parallel. If this turns out to be accurate, then the m20 sits at a 30 degree tilt. This is my final answer (also my first answer…).
                  I was born on 3/25…
                  • camshaftgsxr
                    • Aug 2011
                    • 416
                    An m50 sits around 30 degrees and when using an e30 transmission on the back of one for a swap the selector rod and transmission mount both need to be twisted 10 degrees, by that information we can assume the m20 is a 20 degree inline 6. another thing is that the side of the oil pan doesnt sit inline with the side of the engine block, it is slightly angled in as it goes down, nor does the bottom of the oil pan sit parallel to the head mounting surface on the block (head gasket). with the engine arms tilted equally and sitting an equal distance from the ground the top of the block mating surface (head gasket) is almost exactly 20 degrees, which supports the fact that the selector rod needs a 10 degree twist and the m50 sits at a 30 degree angle. in reality its probably not 20 but its very close, assuming that the engine arms are mounted evenly on the subframe.
                    BroWorks.com Bro is a lifestyle
                    • Bimmermaven
                      • Apr 2013
                      • 3
                      so, has anyone put an OEM ZF 4HP22 (from a 91 325iC) back in with an M5x/S5x? is the extra 10 degrees tilt workable?
                      oil pan in the trans tilted....
                      shift lever adaptable?
                      FYI, the Type A 4HP22 is rated for 265 ft-lbs torque.
                      thanks
                      • 82eye
                        • Jan 2009
                        • 2104
                        thanks
                        if the goal is staying auto then you'll probably need one of the a4s/a5s auto transmissions from the e36.
