m20 advice
  • Bmwb
    • Jan 2013
    • 196
    m20 advice
    got a question to ask
    had an 2.9l stroker metric mechanic pistons stock rods , block was o ringed , welded cylinder head
    now after driving it a bit with a shitty tune which i shouldn't have done but i did so that is in the past now,
    specs on what the engine had
    the question is i had Pistons** 2900 Sport, 86mm, Hard Anodized, 10.0:1 CR
    now those pistons are fried and are nothing but a paper weight i had my fun but its time for a fresh build once again , but this time i wanna lower my compression if i still could or ill get a new block
    is there any way i can lower my compression using 86mm pistons and what pistons would i need to do so ,
    im still using the 885 head its still clean with a 272 cam and im going to be buying heavy duty rocker arms
    with some aftermarket or brand new m20 valves ,
    the engine held up and did not blow the head gasket at 25psi just melted the pistons , also running methanol bought a huge can from JB power source
    . also forged rods is what im probably gonna end up buying and properly build up the motor with a good friend of my dads which will be helping me with this build , i would ask him about the pistons but hes a vett guy and owns a supercharged classic stingray
    Sold Black BMW E30 325IS
    1987 bmw e30 euro part out
    1990 Bmw 325i Cabrio 2.9
    Metric Mechanic 2.9 stroker
    Holset Hx35w CXRacing Manifold
    MegaSquirt ARP HeadStuds
    OEM HG AEM Methanol injection
    20psi
    • 37833
    I'd go with some Ross Racing pistons. You can order them through Ireland Engineering. The standard "off the shelf" compression they carry is 9.75:1 but you can custom order them with the compression of your choice. It sounds like you should do 8.5:1, maybe 9:1 at most.
    Grover Beach, California
    BimmerHeads.com
