Ok - I have searched many threads and understand how to do the Stomp test but I cannot seem to answer a couple of questions.
I have a 1991 BMW 325i and recently had the check engine light turn on briefly during a cold startup and at idle - then car died - restarted light was on - then disappeared a few seconds later..
Drove home, parked the car - have started it 3 times since - did not drive it anywhere - not the 5 times to take it to reset.
I tried the stomp test several times and get no flicker.. I put car in neutral - turn ignition to on - lights all appear - do not start - depress accelerator 5 times and nothing happens - check engine light does not go off - it does not flicker..
Question - if the check engine light is not on when running - will the stomp test reveal anything?
Question #2 - if there are no fault codes - will the check engine light flash at all?
Question #3 - If the check Engine Light briefly comes on - is a code stored?
I am not sure but I do believe I have the BOSCH Motronic 1.3 - but havent confirmed that yet... I am guessing as it is a 1991 325i..
I understand if the stomp test does not work - it may be the TPS - but I tried this on 2 vehicles (my son's IX and mine) and I get nothing..
