So for the past 2 weeks I've been experiencing this problem. On a cold start, my car's idle alternates for a few seconds from 600-1500. It settles after a while but it moves up and down every once in a while. Sometimes when downshifting and I try and rev match, the car won't rev and the check engine light will blink for a split second. Sometimes when driving the car "hesitates" upon acceleration and the RPMs drop and shoot back up again, causing a kick or a stutter when driving. Again, the check engine light flashes for a split second as this is happening. I did the stomp test and the code was 1215, which is the AFM. I changed the AFM and the problem is still here... but worse. What else could the problem be? Vacuum leak?
EDIT: I checked my intake boot (as I heard that's a common area for vacuum leaks) and noticed there's a crack or tear about an inch long on it. It doesn't seem like any air could escape from that as it's only on the surface, but could that be it? The problem seemed to get worse after I fiddled with that.
