Fuel leak under intake manifold/throttle body
  • Falconer
    • 156
    Sometimes, warm or cold, it takes about 3 times to start. After that, it idles fine. I've noticed the smell of gas in the engine compartment, and today I finally caught it in the act (I think); it dripped onto the plug shown below. Everything under there is kind of soaked with gas in general. What could be leaking?
    1981 320is, Alpine White, 5 speed (Sold)
    1992 318is, Brillantrot, 5 speed (Sold)
    1996 328i, Montreal Blau, 5 speed (Sold)
    1991 325i Coupe, Alpine White II, 5 speed (Current)
  • efficient
    • Feb 2012
    • 3312
    Have you checked the fuel hoses?
    • mitchlikesbikes
      • Dec 2013
      • 858
      this same thing happened to me, turned out that i had knocked the fuel rail loose from one of the injectors when i was prying around changing my thermostat housing. i would check your hoses and then see if the injectors are all seated/sealed properly
      IG: @mitchlikesbikes
      • AndrewBird
        The Mad Scientist
        • 11898
        DO NOT DRIVE THE CAR UNTIL YOU FIX THIS!
        That is an engine fire waiting to happen.
        • Falconer
          • 156
          I swapped in M50 injectors last April, and checked the seating and seals a few weeks ago when I started noticing the raw fuel smell. I'm fairly confident it's not this but I'll check again.
          Yes, a quick examination in poor lighting didn't reveal anything but I'll probably have to take a closer look.
          • EatsHondas
            • Sep 2012
            • 404
            Not that many culprits to choose from. Check the rail and pressure regulator for cracks/leaking fuel, both fuel lines (don't mix them up if you remove them!), and the upper (rail) and lower (intake manifold) o-rings on the injectors.
            1989 325i Lachssilber Sedan
            5-Speed Swapped
            M30B35 Swapped
            MegaSquirt MS3X
            1987 325i Lachssilber Sedan
            260k OEM Automatic Daily Baby
