having issues with this spark plug
  • Killacortes
    • 1937
    So a little background on the car. Its a 885 head on a 2.7l bottom end. The head i used was from a boosted m20 with BPR8ES NGK plugs in them. The car would start right up but felt like it was missing.
    Now knowing that these plugs are not for an NA m20 I went out and bought autolite copper core 64 plugs. With these plugs the car would not start at all. I would constantly get fuel soaked plugs.
    Switching back to the BPR8ES NGK plugs car would start right up again.
    Not sure whats going on here? Are the autolite's also the wrong plug?
    r3v does not fuck around. First you get banned, then they shoot you
  • Hooffenstein HD
    • Nov 2012
    • 1388
    You want BP5ES, maybe BP6ES.
    • Killacortes
      • 1937
      okay ill give that a shot
      • Hooffenstein HD
        • Nov 2012
        • 1388
        I believe BP5ES, or ZGR5A is standard for an NA M20. Probably best for your application since you're running an #885 head.
        It's once you start raising the compression that you may need the slightly colder BP6ES. I've heard they have sorted out a slight misfire with #731 strokers.
        • digger
          • Nov 2005
          • 6216
          BPR5ES/ZGR5A for low com NA and BPR6ES for a higher comp NA
          • Killacortes
            • 1937
            It is a lower comp. Thanks for the advice guys
            • Hooffenstein HD
              • Nov 2012
              • 1388
              Sorry, digger is right. I've quoted the correct heat range but forgot about the R for resistor. Non resistor plugs like the BP5ES are for L-Jet M20's without electronic ignition.
              • Killacortes
                • 1937
                Not sure what's going in here but I went out and tried the BPR5ES plugs and they will not start the car. Seems like only the BPR8ES plugs will work which is a colder plug.
                More background on the engine
                885 head
                Dual pattern cam from bummer heads
                Oversized eccentrics
                HD rocker arms
                Vac dual valve springs
                Adjustable cam gear from bummer heads
                Vac valve keepers
                • Killacortes
                  • 1937
                  Could a bad cps cause this problem?
                  • digger
                    • Nov 2005
                    • 6216
                    i doubt the CPS would only begin to be problematic with a certain plug heat range
                    • Killacortes
                      • 1937
                      That's what I'm thinking too. I did a spark test and both plugs came in very weak. Both the cold plug and the oem.
                      Cap and rotor are brand new bosch replacements
                      Plug wires are in good shape from bremi
                      • digger
                        • Nov 2005
                        • 6216
                        coil?
                        • Killacortes
                          • 1937
                          I swapped the coil out of my running eta. And same problems persisted.
                          • Killacortes
                            • 1937
                            Well realized what was going on here. The plugs I bought did not come pre gapped. They were around .04 and the colder plugs were the right gap. So I re called all of them and boom starts right up. What a stupid mistake lol
