E30 325I catalytic converter
  • DennisJ
    • Oct 2014
    • 82
    Hi,
    Is it possible to rebuild a model with catalytic converter to a model without?
    I asume the exhaust parts will fit - but what about the oxygen sensor?
    Regards
    Dennis
  • digger
    • Nov 2005
    • 6199
    well just remove the catalytic converter any exhaust shop will be able to do it.
    i believe the 1985/86 325i (europe only?) had no cat so there would exist an OEM exhaust system which had no O2 sensor bung, but you could install a bung if you wanted to run the modern Motronic
    the oxygen sensor primary function is for the catalytic converter function and life so its not a necessity but without it expect economy to suffer a bit as stoic is a good allround AFR for light and medium engine loads and without the O2 then there is no feedback system maintaining it
