properly gaping the Crank position sensor
  • profbooty
    • 308
    I know that the proper gap for the CPS (pulse sensor/crank position sensor) is 1mm +/-.3mm according to the Bentley manual, but how do you properly gap that? Obviously you use a feeler gauge to check it, but I don't see any form of adjustment other than leaving the 5mm screw loose.
    Any thoughts?
  • Regnar75
    • Sep 2011
    • 483
    im pretty sure you just tighten it fully and it will be proper gap. (this a motronic 1.1-1.3)
    • PimpinWalrus
      • Oct 2013
      • 170
      I just made sure to use the proper torque measurements and it worked fine for me
      '86 Delphin 335i turbo -
      '88 Schwarz 325i -
      '94 w124 e420 -
      Turbo m30b35 Build Thread
      • TobyB
        • 5296
        I was expecting something really obscene here...
        t
        • 15Michaeljoseph
          • Aug 2013
          • 1693
          t
          --Mike
          (OO=[][]=OO) For Life
          • TimeMachinE30
            • Jun 2014
            • 3749
            As long as the gap is not gaping...
            Is there a torque spec?
            ACS S3 Build / Dinan 5 E34
            • 15Michaeljoseph
              • Aug 2013
              • 1693
              You have to warm it up before you try gaping it I guess.
              --Mike
              • noid
                • 1537
                There is some give to it. What I do is place the feeler gauge between the sensor and the tooth and then tighten the bracket onto the feeler gauge, once tight just remove the feeler.
                Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
                Your resource to tools and tips: www.rtstools.com
