M20 UNDERheating?
  • JinormusJ
    • 6887
    M20 UNDERheating?
    Just did the timing belt/water pump. Everything checked out, everythings good. Replaced Water Pump (Graf), Fan Clutch (Meyle) and 80°C Thermostat (Wahler/176°F)
    Before the timing belt change, my needle was sitting around 11 o'clock (7/16ths on the board), but after the change, it seems to only sit right below the first "1/4th" Hash at like 10 o'clock (around 3/16ths even somtimes) on the board and only heats to barely above the 1/4th hash (5/16ths) only while sitting and idling
    Finding it really peculiar: bleed the system right, heat is blowing strong, reservoir is topped off, brand new thermostat.. Leaves me scratching my head. It was idling for 30 minutes almost before I just called it a night
    Maybe my temp sensors just died? Finding it really hard to believe though considering the sheer coincidence of it all and my cold starts are fine and I'm not getting any CELs
    SOLVED:
    Faulty new Thermostat, changed back to my old one; sits pretty at 7/16ths like is should (around 80°C mark)
  • Todd Black 88
    • Oct 2007
    • 3449
    What tstat. Was in it before?
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • JinormusJ
      • 6887
      No idea
      Looked like a generic autozone brand: it was an engine swap, and I'm just clearing up all the loose ends (Fan Clutch, Water Pump, Thermostat)
      Used a Vernet 80°C thermostat before on other timing belt changes and it always heated at 7/16ths, which only means the unknown tstat had to be 80° based on similar cooling
      This is my first time ever messing with the timing belt and having cooling/heating issues afterward
      • JinormusJ
        • 6887
        M20 UNDERheating?
        According to this picture
        Gauge sits at 62° when it should be sitting just below half at 80°
        • mitchlikesbikes
          • Dec 2013
          • 858
          verify your temps with an infrared thermometer then go from there
          IG: @mitchlikesbikes
          • JinormusJ
            • 6887
            Go where from there.. Exactly..?
            If it makes any difference, I checked this morning with a traditional food thermometer at the coolant temp sensor hole and it read 150°F (65°C)
            Could my coolant minute have anything to do with it? I used to do 50/50 blends BMW OEM coolant, but this change I switched to 60/40 water/coolant BMW OEM mix
            • EatsHondas
              • Sep 2012
              • 404
              Had the same problem using TWO DIFFERENT 80C Stant t-stats from Advance Auto Parts. Switched to a Wahler t-stat, bled her all the way, and now it lingers about a needle's width to the left of 12 o'clock.
              1989 325i Lachssilber Sedan
              5-Speed Swapped
              M30B35 Swapped
              MegaSquirt MS3X
              1987 325i Lachssilber Sedan
              260k OEM Automatic Daily Baby
              • HennaE30
                • Apr 2014
                • 1965
                Yes. It will. The more water you run in your car, the longer it'll take to get warm, as well as possibly running cooler. Water displaces heat better than ethylene glycol (most coolants) causing it to run cooler.
                Originally posted by flyboyx
                how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
                Originally posted by Northern
                beer is my new liver cleanse.
                Henna - '84 Hennarot 325e
                Lola - '89 Schwarz 325is - being saved
                Christine - '88 Schwarz 325is - Spec E30 Racecar
                '01 White F150 Lariat 4x4 Supercrew - Daily
                Dad's '05 Interlagosblau M3
                • JinormusJ
                  • 6887
                  You know, you were the exact person I was thinking about when I typed this up. The whole time I was thinking.. Man, remember when I was wrong about coolant and I told Henna?
                  Gonna run and get myself another jug of BMW coolant and refresh the system. Hopefully that solves it
                  • ak-
                    • 12422
                    Don't think that gauge is accurate. Mine once sat at the "106" Celsius position for whatever reason according the picture you posted, and Tuner Studio was saying 210* Fahrenheit, which is 98* Celsius.
                    1991 325iS turbo
                    • CorvallisBMW
                      Long Schlong Longhammer
                      • 13039
                      You can test your t-stat but placing it in a pot and heating it on the stove. Use a thermometer to verify the temp that it opens at.
                      • HennaE30
                        • Apr 2014
                        • 1965
                        Here, 60/40 is worthwhile in the summer time because it gets hot (a couple years ago we have 63 straight days over 100 degrees) from April to September. But if it's not consistently how 60/40 makes no sense unless you track the car a bunch. Unless your running hot already, changing 60/40 is pointless.
                        And I was thinking of that instance while reading this too, laughing to myself.
                        • DaveSmed
                          • Apr 2007
                          • 1407
                          Truth. Those gauges aren't worth a damn as far as measuring. They just show relative temperature on your specific car (basically if it goes to the same spot it always does, good. If not, check it out)
                          They also vary signifigantly car to car. There are something like 15-18 total connections in that circuit, (around 5 dedicated) and that coupled with 25 some odd years leads to a bit of variation.
                          -Dave
                          2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                          Need some help figuring out the ETM?
                          • crappycoco
                            • May 2014
                            • 250
                            Mine does the exact same thing since i got it. I have 50/50 pre-mixed prestone coolant in there and thats it. While driving through death valley and/or autocrossing, it can get close to 12'o'clock or a hair over it.
                            • JinormusJ
                              • 6887
                              Day before timing belt: heats to 7/16ths
                              Day after timing belt: heats to 1/4th
                              Therefore, "if it goes to the spot it always does, good, if not, check it out". So.. Then.. I digress
                              I never claimed these gauges were accurate, I'm posting this thread because my car is doing something it was never doing before: eg under heating to 1/4th versus heating normally to 7/16ths (which is what my car used to heat at)
                              I thought of trying a different mixture because during summer here it gets consistently 100+ and on freeway days I would consistently "over"heat to 9/16ths on my gauge; whether or not that's attributed to the fan clutch; probably, but I thought having a slightly more water-biased mixture on top of replacing the clutch would be good but didn't think it would effect normal operating temperatures this much
                              Either way, I was close, but no cigar on adding the 50/50 mix; still heats to 1/4th when the norm for this m20 should be 7/16ths
