reverse jump no start
  • bastianshaw
    • Jan 2007
    • 2210
    so my buddy put his battery in his car backwards and now it wont start just cranks i cant figure it out...ecu?
  • dnguyen1963
    • Nov 2011
    • 2651
    Fried ECU?
    • bastianshaw
      • Jan 2007
      • 2210
      Originally posted by dnguyen1963
      Fried ECU?
      That's what I'm asking
      What else?
      • Cabriolet
        • 9620
        see if you killed the fuse-able link
        Much wow
        I hate 4 doors
        • bastianshaw
          • Jan 2007
          • 2210
          It's really weird it just cranks and cranks I found that if I unplug the icv it will actually fire but won't run at all. But It does combust leading me to believe that the Ecu is functioning and getting timing data from the cps so it SEEMS like the ecu is working. It's been sitting for along time maybe it's bad gas?
          • Chessmaster
            • Jun 2012
            • 501
            Try a stomp test, see what codes it throws out to give you some idea of what the ecu senses is wrong.
            • 5Toes
              • 9836
              if the CEL doesnt come on when ignition first is turned on then DME is NOT powering up
              • bastianshaw
                • Jan 2007
                • 2210
                Cel is deff there i don't get what could make it stop running after it kicks over
                Again it will only fire if the icv is unplugged I cleaned that out but still no running
                It's been sitting for awhile.
                • mitchlikesbikes
                  • Dec 2013
                  • 858
                  so you're saying it wasn't running before the battery mishap? if it's just been sitting and not ran beforehand there's a lot of things it could be that have nothing to do with the battery thing.
                  IG: @mitchlikesbikes
                  • bastianshaw
                    • Jan 2007
                    • 2210
                    No it totally ran. But it was sitting for awhile so the battery went dead and after charging we are here. I'm really surprised it's been sitting for like 7months
                    • bastianshaw
                      • Jan 2007
                      • 2210
                      im totally
