completely lost need some serious help with idle and low power
  • bmwcarnute30
    • Jan 2015
    • 123
    so guys i was having a lose of power and idle issues. I own a 1990 325i vert. To start this off i will make a list of every part i have replaced.
    Replaced with new:
    Distributor cap
    Rotor
    Ignition wires
    alternator
    battery
    oxygen sensor
    MAF (with known working)
    timing belt
    head gasket
    vacuum hoses (eliminated any leaks)
    Brake Booster (had internal vaccum leak)
    water pump
    airfilter
    Parts ive cleaned:
    MAF
    ICV
    Had intake manifold sand blasted inside and out
    Fuel injectors
    THE PROBLEM!
    the problem i have been chasing is that ive had hard cold starts but once its warm is will idle fine but if i give it gas it
    will sometimes hesitate but then rev up nice a clean but once i let go of the gas and the rpms go down it will dip below
    idle and either stall (most likely) or stutter and catch its self and continue idling. i also notice a large loss of power.
    please let me know on your thoughts and if im missing some information just ask and ill give you what i know.
  • bmwcarnute30
    • Jan 2015
    • 123
    i scanned my car for codes and im getting 1 code for icv. If i replace it i find it unlikely that its my only problem. Thoughts? also anyone got a t shaped ICV for sale
    • tim88325is
      • Jul 2008
      • 201
      Ever do a compression and/or leak down test?
      • bmwcarnute30
        • Jan 2015
        • 123
        i just rebuilt the head and the engine was at 90 original miles i doubt that is the problem as the car wasnt running this bad before i pulled the head.
        • tim88325is
          • Jul 2008
          • 201
          I would still do it, the fact that the head was rebuilt even lends more to a valve issue.
          Also, what issue caused you to rebuild the head?
          I don't see it much on this forum but more old-timey mechanics will do a compression test with nearly any new problem to rule out serious problems and create a base line to work from.
          • bmwcarnute30
            • Jan 2015
            • 123
            i was pulling the intake to get the injectors cleaned and then it turned into a while you're in there project.
            anyway it seems almost like im running on 5 cylinders. im going to check to see if im getting spark at all 6 when i get the chance and the report back.
            if not ill bring it to work and do a compression test
            • tim88325is
              • Jul 2008
              • 201
              Since you probably took apart the C191 connector under the intake, I would make sure it is not corroded on either side where the wires feed in, under the rubber boots. That connector can be a big source of problems, even intermittent ones. Any problems can get worse if the connector is disturbed since the corroded wires are usually holding on by a thread...
              • Zalmoxis
                • Nov 2014
                • 68
                I have the same problem, I'm replacing the coolant sensor coolant temp sensor and the water temp sensor !idk where
                The purple one goes !!
                • bmwcarnute30
                  • Jan 2015
                  • 123
                  they both go in the same spot right next to each other
                  • Zalmoxis
                    • Nov 2014
                    • 68
                    I hope that will fix my idle ! I've changed two airflowmeters I have 3icv and everything else related ! If this won't do it then .. I'll
                    Shoot the block with a magnum and put a 1jz or ls! Neaahhh I'm just pissed :))) thanks bmwcarnute30 !! I think I know what you're saying !! Thanks ! Right on top of the front of the block on the right side by the valve cover ! I'm heading right now to the garage ! I'll keep you posted !
                    • bmwcarnute30
                      • Jan 2015
                      • 123
                      do you have a t shaped working icv for sale?
                      • Zalmoxis
                        • Nov 2014
                        • 68
                        so the purple goes in the 2nd hole ?! If this fixes my car I'll sell you a t shaped ICV ;)
                        • Zalmoxis
                          • Nov 2014
                          • 68
                          The plugs are different :-/ I can't find the purple one ... Online either ! I have a 90 325i if it makes a diff
                          • bmwcarnute30
                            • Jan 2015
                            • 123
                            the color of the sensor should correspond to the color of the connector if irc.
                            • Zalmoxis
                              • Nov 2014
                              • 68
                              They are not the same ! I can't find a purple switch ! fuxk this switch ! I changed the other one just in case, I found a disconnected hose it was loosing vacuum I plugged it the car runs better .. But still no choke ..
