Wish I would've known about the sprockets, possibly braking, before I had changed my t-belt!
Has Anyone Ever Seen This - Timing Belt
Holy shit did you even read this post before you posted?
http://www.r3vlimited.com/board/announcement.php?f=156
This thread sure sucked last night. It just plain sucked. I've seen threads suck before but this is the suckiest bunch of sucks that ever sucked.
Originally posted by 101 View Post^^^ Correct. The sprockets themselves can shear. They are just stamped sheet metal vs. the newer style which is a LOT beefier.
Here's an older thread on the topic with comparison pictures:
http://www.r3vlimited.com/board/show...hlight=stamped
Originally posted by 101 View PostThe spring and pin are sold separately from the timing belt kit. Around $5 for both from the stealer.
I've seen M20 engines where the spring is missing. I had one. While I understand that once the tension is set the spring really doesn't do anything more - it basically remains there in case the bolts holding the tensioner in position would ever back off.
I also always replace the stamped camshaft and oil pump drive gears with the updated cast ones when I encounter them. It looks like you have the stamped gear on your oil pump drive.
Do you have the part numbers for those? I thought the stamped oil pump gear looked weird when I did mine but it felt solid. If I had known there were updated versions I would have changed that one while I was at it.Thank god, R3V was getting boring since the ginger kid wrecked his car. - Stonea
$42.53 list price for the cam gear
$23.51 list price for the oil pump drive shaft gear
I replace the attaching bolts as an added measure of caution.
101
The E30 collection:
1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
1987 325is - Delphin / Black Sport (son #3's)
1987 325i Convertible - Triple Black
1989 325iX Coupe - Diamondschwarz / Black Comfort
1990 325iX Coupe - Sterling Silver / Grey Sport
1981 Fiat 124 Spider 2000 - Green / Tan
1998 Volvo V70 GLT - White / Tan
1998 Volvo S70 T5 manual - White / Taupe
2001 Ford Windstar - Silver / Grey (parts hauler)
2006 Lexus GX470 - White / Tan (tow rig)
Here's a related question - camshaft seal - how often should this be replaced?Estoguy
Originally posted by estoguy View PostHere's a related question - camshaft seal - how often should this be replaced?
