Has Anyone Ever Seen This - Timing Belt
  • Peelsbimmer
    • Dec 2012
    • 178
    Wish I would've known about the sprockets, possibly braking, before I had changed my t-belt!
    Holy shit did you even read this post before you posted?
    http://www.r3vlimited.com/board/announcement.php?f=156
    This thread sure sucked last night. It just plain sucked. I've seen threads suck before but this is the suckiest bunch of sucks that ever sucked.
    • turbo55
      • Jul 2014
      • 223
      Originally posted by 101
      ^^^ Correct. The sprockets themselves can shear. They are just stamped sheet metal vs. the newer style which is a LOT beefier.
      Here's an older thread on the topic with comparison pictures:
      http://www.r3vlimited.com/board/show...hlight=stamped
      So only the oil drive sprocket needs to be replaced (based on the thread link above)? And also it looks like its something you get from the stealer? Any idea how much?
        • 34847
        No, both the cam & oil sprockets should be replaced.
        • Mwishlist
          • Jul 2013
          • 505
          The spring and pin are sold separately from the timing belt kit. Around $5 for both from the stealer.
          I've seen M20 engines where the spring is missing. I had one. While I understand that once the tension is set the spring really doesn't do anything more - it basically remains there in case the bolts holding the tensioner in position would ever back off.
          I also always replace the stamped camshaft and oil pump drive gears with the updated cast ones when I encounter them. It looks like you have the stamped gear on your oil pump drive.
          Do you have the part numbers for those? I thought the stamped oil pump gear looked weird when I did mine but it felt solid. If I had known there were updated versions I would have changed that one while I was at it.
          Thank god, R3V was getting boring since the ginger kid wrecked his car. - Stonea
          • Mwishlist
            • Jul 2013
            • 505
            Never mind, just caught the link to the other thread.
            • 101
              • Jul 2011
              • 764
              $42.53 list price for the cam gear
              $23.51 list price for the oil pump drive shaft gear
              I replace the attaching bolts as an added measure of caution.
              http://www.realoem.com/bmw/showparts...65&hg=11&fg=25
              101
              The E30 collection:
              1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
              1987 325is - Delphin / Black Sport (son #3's)
              1987 325i Convertible - Triple Black
              1989 325iX Coupe - Diamondschwarz / Black Comfort
              1990 325iX Coupe - Sterling Silver / Grey Sport
              1981 Fiat 124 Spider 2000 - Green / Tan
              1998 Volvo V70 GLT - White / Tan
              1998 Volvo S70 T5 manual - White / Taupe
              2001 Ford Windstar - Silver / Grey (parts hauler)
              2006 Lexus GX470 - White / Tan (tow rig)
              • turbo55
                • Jul 2014
                • 223
                Just ordered the camshaft and oil sprockets from TurnerMotorsport for $36.95 and $23.95. They also had the spring, pin, and camshaft seal/oring for good prices too.
                • estoguy
                  • May 2013
                  • 1087
                  Here's a related question - camshaft seal - how often should this be replaced?
                  Estoguy
                  • Andy Mechnic
                    • Jan 2015
                    • 117
                    Every time youre in there, provided you're not going back in there because you monkeyed something up.
                    • turbo55
                      • Jul 2014
                      • 223
                      Mine is leaking, I'm gonna replace it. It looks like it should be pretty easy to do if you're already in there for the timing belt, and the seal and o-ring was $4 and $1 from Turner. So yeah I'd say you might as well do it every time.
                      • turbo55
                        • Jul 2014
                        • 223
                        Update: the belt was rubbing because the belt tensioner had failed and was cocked to the side. Here's a side-by-side with a new Gates one:
