Vacuum leaks
  • TRIZZY
    • Mar 2015
    • 11
    Vacuum leaks
    Hi I recently purchased a 1986 325es
    The idle on it is a little weird jumps around from >1000-1500rpm. I think I might have a vacuum leak somewhere and as I am new to the forum and e30's I was wondering if someone could help me with details about what hoses to check for leaks and to replace.
    Also what is a normal idle rpm in an e car?
    Thank you!
  • dnguyen1963
    • Nov 2011
    • 2651
    To find all the vacuum leaks, you need to do a proper smoke test. If you do not know how then have a shop perform one for you.
