Blue Loctite on Oil Pan Bolts?
  • GOT8SPD
    • 270
    Recently I changed my oil pan gasket and found the car was losing more oil than before after it. I went back, checked all the bolts, and all of them are slightly loose now.
    Can I just take the bolts out, add loctite, and put them back in, or do i need to use a new oil pan gasket? It's the OE BMW cork gasket
    SHOULD I even add loctite to the bolts?
    Thanks.
    • 37833
    There is no reason to locktite the bolts. Just make sure they're tight.
    Grover Beach, California
    BimmerHeads.com
    • ELVA164
      • 4861
      The cork will squish a little when it's first installed. That's probably the source of the loosening.
      • ebox86
        • Sep 2012
        • 528
        Is anything like gasket maker or some type of sealant recommended on top of the cork or is just the cork gasket fine?
        '99 e46 323i - wrecked
        '87 e30 325iS - sold
        '91 e30 325i - sold
        '89 e30 M3 - fun car
        '09 e91 328i - sold
        '97 impreza - rally car - flipped
        '08 impreza - new rally car
        '01 996 tt - more fun car
        '82 Ford f350 - work truck
        • JUNGLISTluder
          • 236
          Just did this to my car the other day. Installed a new oil pan last fall and found oil all over my skid plate recently. Removed the skid plate and all the oil pan bolts were .25-.5 turn loose from the engine virbration and intial gasket shrinkage. I retorqued them all without removing or locktiting them and I haven't seen the problem return.
          BMW e30 318is
          BMW e30 318iC
          BMW e28 528is
          Range Rover HSE
          Ferrari F355 GTB
          • meengreene30
            • Mar 2012
            • 369
            I always try to find paper oil pan gaskets, hate the cork ones. Use a little RTV at the corner areas. In a week or so i check to make sure the bolts are tight.
            • GOT8SPD
              • 270
              I was suggested by iwantspeed to use Gasgacinch
              http://www.amazon.com/Edelbrock-9300...ords=gasacinch
              I'm going to re-torque the bolts that I'm able to get to and hopefully the puddle goes away
              • GOT8SPD
                • 270
                thanks everyone for the comments.
                • digger
                  • Nov 2005
                  • 6199
                  i would use a flexible sealer/silicone on the interfaces once they are meticulously cleaned, lightly/snug install bolts until sealer has fully cured, then tighten it the rest of the way after curing.
                  since the bolt grip length is short and the joint is a flexible one it can relax a bit when heat cycled and the bolts may loosen somewhat so check it after use
