New oil pan gasket seeping....
  • BMWManiac
    • Dec 2010
    • 1091
    I had a shop install a new gasket...problem is, I moved and can't just have them fix it.
    So, can I drain the oil, drop the pan, maybe clean the area and use some RTV on the corners and then reinstall? It is wet at the rear on the passenger side.
    1997 Artic Silver M3
    CES GT4094r 651hp/615tq @ 24 psi
  • Som
    • Jan 2014
    • 126
    Every oil pan I've ever dropped (a grand total of 2) destroyed the gasket when it was removed. That said, both cases were on a motor with 6-digit odo readings.
    Either way, I'm guessing you'll want a new gasket. The gasket itself is cheap anyway. Dropping the pan and cleaning the surfaces are the time consuming parts, so you might as well swap the gasket out while you're at it in case it tears when you remove the pan.
    On the E36 pan I dropped, I put light RTV on just a couple corners (on the tranny side) of the gasket before reinstalling. They were around areas where the block's surface (if I remember right) naturally had an area where 2 metal parts met up and there was an obvious seam. So the RTV was intended to kinda fill the seam and not allow oil to seep out.
    On the E30 pan, I was installed a crank scraper, so I had used RTV all around the block-to-scraper side, and a cork gasket on the scraper-to-pan side (since there were no seams in the scraper metal to worry about).
    I don't really remember, but I'm guessing the same seam exists on the M20 that requires a dab of RTV on the rear corners. Maybe the shop missed this?
    Som
    • BMWManiac
      • Dec 2010
      • 1091
      Yes, the shop installed it dry, which is why I was thinking I could probably just lower it, wipe away any excess oil, and then apply a dab of Permatex 2 or something else and reinstall....guess it is worth a try and if it doesn't work, go through the process of complete removal...
      • Klug
        • Sep 2011
        • 804
        The first time I replaced my pan I didn't listen to the DIYs and used RTV. Bad Move. It leaked for about two years and progressively got worse. Re-did the gasket with Permatex 2 and it held SO much better. Put a dab around one side of the whole gasket and it's been working out great. Even using a plane jane cork/rubber gasket, it made a good seal.
        555Garage - Kingston, PA
        '13 BMW e70 X5 35d
        '95 BMW e34 525i
        '92 BMW e30 325i S52 Vert (Quade the Vert)
        '92 Range Rover Classic
        '90 Range Rover Classic
        '89 BMW e30 325i Coupe (The DIRTY30)
        '81 VW MK1 Rabbit Caddy Diesel
        '76 Honda CB550K Cafe/Brat
        '67 Pontiac LeMans
        '24 Model T Depot Hack
        ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
        • Mr. Tasty
          • Jul 2011
          • 3421
          I had issues of the bolts backing out. A simple re tightening and it has been leak free for a year.
          2014 Alpine White 335i MSport
          (Daily Driver)
          Full Mperformance Aero
          KW V2 Coilovers
          VRSF Catless Downpipes
          • BMWManiac
            • Dec 2010
            • 1091
            Great, I'll check it. Since the gasket has less than 1k miles, is it worth just dropping the pan, applying Permatex #2 or another sealant, and rebolting everything back up? I guess it couldn't hurt and if it works, it works, and if it doesn't, out comes the whole shabang!?
            • actletpone
              • Oct 2013
              • 20
              IMO it is not worth it, for the price of a new gasket just get a new one. Each to their own but I hate doing things twice, do it once do it properly. They may have over-tightened I and / or ripped it. Sounds like you might have already decided though.
              The m20 sump gasket job is honestly easier than I thought it would be. Jack up car, unbolt engine mounts, jack up engine with ac pump bracket or similar, unbolt oil pan, then unbolt the oil pump and drop it into the pan, then it slides out. Might want to unbolt your gearbox mounts too, keep an eye on them. Clean oil strainer while you are there. I used cable ties through the sump bolt holes and gasket to help keep it in place during reassembly.
              • Klug
                • Sep 2011
                • 804
                Just do it right the first time, don't reuse a gasket...regardless of the age. Once its mated, mating them together again with whatever sealant might work, but more than likely it will still leak.
                '13 BMW e70 X5 35d
                '95 BMW e34 525i
                '67 Pontiac LeMans
