Hey r3v,
My 325i has been developing an issue where it will stumble pretty badly above the 2k mark while accelerating. It did this a couple times about 3 months ago and then didn't do it again until yesterday, so I more or less forgot about it. Based on my searching, it sounds like it could be the c191 connector, fuel pump, fuel pump relay, afm, or tps. The c191 seems like the most likely culprit to me, but one common theme of this problem is that it almost always happens after I rev the motor up around 4k or so, which makes it sound like more of a fuel pump issue. Anybody had this problem before? And what ended up being the culprit?
