Replacing Camshaft Seals?
  • GOT8SPD
    • 270
    Ok so the O ring Im talking about is DEFINITELY not like the pic posted by 87E30VERT. That o ring is a hard seal where as the o ring I got is different. The orange ring shown above is a hard o ring and that seal was on part #4 and I did have that part when i took off part #4. Since it was so different from the thin o ring I got (it's a flimsy flexible o ring) I thought there's no way it was designed to go in that groove. This is what I ordered.
    http://www.ecstuning.com/ES2803827/
    • crappycoco
      • May 2014
      • 250
      Could it be that the squishy o-ring got hard (giggity) because of age? Because I had several turn as hard as plastic when I pulled them, which is why they don't seal anymore btw =)
      • GOT8SPD
        • 270
        I'm not sure? it's just so thin to fit in that groove, i doubt it would seal anything.
        • crappycoco
          • May 2014
          • 250
          hm, go on and fit it - then take a picture and post it. I'm sure someone will be able to help you.
          • 87E30VERT
            • Apr 2015
            • 129
            So upon receipt of the o ring I was wondering that same thing. I am actually tackling this tomorrow and will have a better answer at that time. The o ring just appears too loose to fit in the guide snug but I haven't physically tried yet...that was just my initial impression. Check out this video on YouTube:
            At about 19:15 he covers the camshaft seal and o ring replacement.
            Here is a screenshot from video:
            Early Model Front License Plate Filler for Sale: http://www.r3vlimited.com/board/showthread.php?t=363721
            Late Model Front License Filler Plate for Sale: http://www.r3vlimited.com/board/showthread.php?t=365118
            • 101
              • Jul 2011
              • 764
              A new o-ring does fit loose in the groove. Once it's installed it will compress and expand to fill the groove area.
              101
              The E30 collection:
              1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
              1987 325is - Delphin / Black Sport (son #3's)
              1987 325i Convertible - Triple Black
              1989 325iX Coupe - Diamondschwarz / Black Comfort
              1990 325iX Coupe - Sterling Silver / Grey Sport
              1981 Fiat 124 Spider 2000 - Green / Tan
              1998 Volvo V70 GLT - White / Tan
              1998 Volvo S70 T5 manual - White / Taupe
              2001 Ford Windstar - Silver / Grey (parts hauler)
              2006 Lexus GX470 - White / Tan (tow rig)
              • digger
                • Nov 2005
                • 6199
                The o-ring goes to square cross section over time due to the heat and pressure
                • 87E30VERT
                  • Apr 2015
                  • 129
                  Thanks guys....you made me feel more comfortable when I tackle it tomorrow. I'm sure the OP feels the same way.
                  • potatomash
                    • Nov 2014
                    • 203
                    How do you get the cam seal housing off? I've undone the two bolts holding it on but it seems pretty solidly stuck there.. :/
                    T U R B O - M 2 0 - B U I L D
                    M U S C C O O
                    • spdracrm3
                      • Sep 2009
                      • 959
                      Use two flatbladed screwdrivers at corners of ears (as close in to the flange center as possible,don't want to break the ears),and pry evenly making sure housing stays square to head .if you can't get it to start moving sometimes rotating flange first will allow it to move either by tapping with punch or gently with large channellock pliers
                      Sent from my SM-G360V using Tapatalk
                      Angus
                      88 E30M3 X2
                      89 325IX
                      92 R100GS/PD
                      • GOT8SPD
                        • 270
                        I used a razor blade to wedge it between and kinda made my way around, eventually, there was more and more room, so then i started turning / wiggling it to make it come out.
                        • Turbo Joe 87
                          • Jul 2015
                          • 14
                          Use channel locks to rotate the seal housing so the ears are vertical. Gently pry at the lower ear, in the recessed area, rotate 180 deg, repeat until it comes off easily.
                          Joe
                          • e30topdown
                            • 94
                            I know this is reviving an old thread, but someone may find this info useful. It certainly would have helped me out.
                            So I just replaced the cam seal and o ring last night. After lubing the end of the cam and the inner lip of the new seal, I couldn't get the seal started on the cam without rolling the seal lip. So I did some research. There's a special tool from Baum Tools, blah, blah. The Bentley manual mentions putting tape over the end of the camshaft to avoid damaging the new seal. So I got some vinyl electrical tape and covered about an 1/8 inch of the cam with it, then folded the rest of the tape down over the end of the cam. Put oil on the tape and cam and the inner lip of the seal...and the damn thing slid right on slick as you please!
                            And I thought the Bentley was only good for torque specs.
                            92 325iC Diamantschwarz factory M-Technic appearance
                            99 M Roadster Dakar Yellow II
                            97 318ti Active Bostongrun DD
                            01 Z3 3.0i Coupe Black Sapphire
                            93 325iC Schwarz II. Sold, but not forgotten.
                            • Campbelljj
                              • Jan 2015
                              • 111
                              Sweet tip
                              • Seawolf
                                • Feb 2015
                                • 270
                                Take a small smooth plastic container (like a small clorox wipes container. It needs to be big enough to fit over the camshaft end.
                                Cut the top and bottom off.
                                Make 1 split end to end.
                                Slather some grease on it and fit it over the end of the camshaft.
                                Scroll the other end of the split container enough to put the oil seal and housing on.
                                Slide onto camshaft.
                                Remove oil seal fitting 'tool'
                                You need something made of fairly robust plastic - otherwise the seal will collapse the plastic as you try to fit it.
