Simple cam tuning rules for NATURALLY ASPIRATED engines:
* Advancing both cams => more low-RPM power, less high-RPM power
* Retarding both cams => more high-RPM power, less low-RPM power
* Less overlap => more low-RPM power, less high-RPM power
* More overlap => more high-RPM power, less low-RPM power
If the cam timing was retarded mechanically, but the ECU timing was advanced with the MarkD chip would that mean a significantly more pronounced "bump" up top? It seemed to pull noticeably harder with the chip around 3500 rpm. If the m20b27 has low end enough to compensate, would it work?
If this was the case, it would explain the rough idle and maybe a sluggishness(?)
