M20B25 - fuel doesnt start
  • DennisJ
    • Oct 2014
    • 82
    Yes. I have checked them all.
    • dnguyen1963
      • Nov 2011
      • 2651
      At this point, I would suggest that you take your stereo out and put everything back to the original state to see if you can start the car. Putting a stereo into an E30 has caused so many problems, especially if the wiring system has already been butchered.
      • bronzite30
        • Feb 2015
        • 12
        Originally posted by E30-325iS
        The ECU needs to see pulses comming from the CPS before it will turn the fuel pump on. Check the CPS, the specs are in the Bentley or swap it with a known working one.
        I thought the fuel pump turns on when the key is in the run position?
        • DennisJ
          • Oct 2014
          • 82
          Already done. No change. :)
          • E30-325iS
            • Sep 2011
            • 191
            No it doesn't.
            • dnguyen1963
              • Nov 2011
              • 2651
              Have you tried a different ECU?
              • DennisJ
                • Oct 2014
                • 82
                Nope. Have to buy one then...
