Harmonic balancer/vibration dampener help
    How does this thing come off my m20b27 1986 325e?
    Got the 6 "crankshaft" bolts off, pulley is off, balancer/dampener won't budge...
    Advice?
    Rescued 1986 325e Coupe
    1988 325ix Touring 5spd currently being rescued
    Ottawa, Ontario, Canada :finger:
    It looks like it's just pretty rusted on there. Spray your choice of lubricant on it, then give it a few taps with a rubber mallet. Should pop free and leave the crankshaft hub behind.
    Just a little project im working on
    - http://www.lse30.com -
      ^ what he said.
      Originally posted by Andy.B
      I was born on 3/25…
        Attack with rubber mallet.
        1989 325i Lachssilber Sedan
        5-Speed Swapped
        M30B35 Swapped
        MegaSquirt MS3X
        1987 325i Lachssilber Sedan
        260k OEM Automatic Daily Baby
          Thanks guys I'll give it another go
            Soaked in penetrating fluid all morning, attacked it...still not budging fml
              keep working her. as long as the 6 bolts are out she'll break loose. maybe a block of wood and a heavier hammer.
                If violence doesn't solve your problem, you're not using enough of it. ;)
                  Violence is the answer
                    There you go...told ya! :)
                      I always go back to the Jeremy Clarkson answer of you weren't using the right size hammer.
