My bitch tube nightmare
  • AntiScope
    • 401
    Okay here we have another story of a leaking bitch tube, leaving an abundant amount of oil everywhere I drive me having to put a drip pan under the car when I park.
    Initially when I took it out the first time, the bottom O ring was non existent. All I had at the time was generic O rings that fit around the tube, but they were too small. It still leaked after that but it was a last resort.
    At last I sourced the correct O ring and installed them on both ends of the tube, used the zip tie trick with the spring, yada yada. INstallation went fine. IT STILL FUCKING LEAKS.
    How is this possible? I've seen that this leak can sometimes be fixed by turning the tube and reseating the O ring but I've tried that to no avail. Any suggestions? I am stumped. I just want to drive my car again.
  • acolella76
    • 2950
    Maybe the block is scored/messed up where it seals? Load up the o-rings with some o-ring grease and see if that helps seal it up
    -Alex
    • AntiScope
      • 401
      That's what I was thinking but it looks fine. I even cleaned it really well. I put oil all over the O ring before installation to ensure a good seal.
      While its in there, I can grab the tube and force it down, and its feeling like its seating fully when I do that. But the spring just pushes the tube back up. Is that supposed to happen?
      • StereoInstaller1
        GAS
        • 22679
        You do have the washer in there, correct?
        I think it's kinda funny seeing your post about bitch tube issues...I don't have the damn seals, can't put this damn intake manifold on...because of 2, rare o rings.
        GL!
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • AntiScope
          • 401
          GL!
          Luke
          Yes the washer is there. Haha, those O rings are hard to find here in Germany. Even the dealership said they'll "call me'. Luckily there was an M20B20 sitting on a pallet behind the skillcenter on post. The O rings looked good. No rips, they weren't dried out. I'm confident they are in there correctly but it's still spewing oil.
          • StereoInstaller1
            GAS
            • 22679
            Of the couple dozen I have done, one 1 leaked...the one I used seemingly good used orings...go figure.
            I noticed RealOEM shows a part number but not a "size".
            Figures finding them is a pain in the dick there too, everyone is like "go to a hardware store" and I'm like "I tried that shit 10 years ago, they don't fucking fit!"
            GL
            Luke
            Closing SOON!
            • AntiScope
              • 401
              GL
              Luke
              Yes it's a very specific size. I can't believe the fucker still leaks. I'm going insane
              • StereoInstaller1
                GAS
                • 22679
                Hang in there man...GLWR
                Closing SOON!
                • ELVA164
                  • 4861
                  Can anyone take measurements of one of them for future reference? Mine seeps some and I'd love to have an idea if it's "getable" anywhere else.
                  • htown318is
                    • Feb 2012
                    • 301
                    i threw in some rtv black for good measure. not fuckin with it again
                    • Dirty325ix
                      • Sep 2012
                      • 689
                      wait there is supposed to be a washer somewhere with the bitch tube....fack, not gonna deal with it
                      im pretty sure this kit came with 2 black o rings when I bought it im sure you can look up the individual contents and get a part number or at least dimension
                      • BenjaminButtton
                        • May 2012
                        • 275
                        RTV the crap out of it.. I used the "Heavy Duty Oil Application" one. Worth a shot.
                        Early models do it better.
                        '86 Cosmos Sedan LS1
                        • AntiScope
                          • 401
                          Should I take the tube out again or just clean it up the best I can and just try and get RTV all the way around it? I don't want to take the intake manifold off again for the third time haha. Fuck that
                          Can anyone confirm if their tube can be seated further like mine? and if the spring pushes it back up? Not sure if that's normal.
                          • vpilarrt
                            • Jun 2006
                            • 2096
                            Yes, the spring is supposed to push the tube up so that it makes a good seal on the bottom of the intake manifold (so you don't get a vacuum leak). Have you closely inspected the tube itself, made sure it's not cracked? You might try a new tube if they're not too expensive (they're $7.50 at Pelican Parts here in the states).
                            • AntiScope
                              • 401
                              Okay thanks for the info. I did inspect the tube as well, no cracks or anything.
