valve stem seal woes
  • cisco
    • Jul 2011
    • 42
    Are there any tricks for getting these on any easier? I put a bit of oil on the rubber and I'm using a 7/16 deep socket as it seems to fit a bit better then the 11mm that the bentley suggests.
  • AndrewBird
    The Mad Scientist
    • 11898
    Tap them on with a soft faced hammer. Should just pop on. Make sure to use the little plastic caps over the end of the valve when re-installing the valves.
    • SkiFree
      • Jun 2011
      • 2766
      Make sure you use the installation sleeves or the seals are going to get cut by the valve grooves.
      ADAMS Autosport
      • cisco
        • Jul 2011
        • 42
        Thanks for the replys, I'm down to my last 5, and don't have any extras. I can't imagine anyone installing a full set without mauling up a few. Just one went "pop" and went right on. I need to PM Mr325 and ask what the secret is. Next time I won't be a cheap ass and just send it out for a rebuild.
          • 37832
          You should be able to oil them and push them in by hand. 8)
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • cisco
            • Jul 2011
            • 42
            OMG! Tight as a cats ass
            Last edited by cisco; 05-06-2015, 12:43 PM. Reason: GF theatens to cut off my peepee if i don't.
