Rich and lean craziness
  • packratbimmer
    • Dec 2009
    • 1334
    Hope you have it up and running soon!
    Cheers
    • SmilesPerHour
      • May 2015
      • 29
      I got the new pump installed today and now it certainly feels a lot more powerful and has that get up and go it lacked before. It's never ran this good!
      On a side note, I also noticed the engine hesitates b/w idle and a little throttle. But not in the middle to high range. That's new. I guess my TPS decided to give me troubles too. Typical! ;p
      • packratbimmer
        • Dec 2009
        • 1334
        Drive it for a bit and see if the ECU adapts back to proper fuel supply. Glad it worked out!
        • SmilesPerHour
          • May 2015
          • 29
          I reset the ECU as I changed the pump, so it should have been expecting a working pump.
          I opened up the TPS and saw a fair amount of oil pooled up in it. A water-park for electrical gremlins basically. =p
          I didn't bother sealing it back up and even added a hole on the underside for future oil to drain through.
