hartge h26 engine question
  • 2002jm
    • Sep 2005
    • 2076
    Going to start collecting all the items I need for rebuilding my h26 next year. It is running fine, but I am sure at some point it will need a rebuild.
    So, would the h26, 323i built in 1984 need a special head gasket? It has the h26 head, and a 2.7 block.
    thanks,
    john
  • kronus
    • Apr 2008
    • 13032
    That depends on your bore. Your headgasket should match the cylinder bore. AFAIK the H26 motor had a stock 84mm bore.
    cars beep boop
    • e30m3s54turbo
      • Jun 2010
      • 3292
      It is a 84x76,80. This what I found for you John.
      I will ask Frank what head gasket we used on my old H26.
      DSC04266 by m3raul, on Flickr
      • 2002jm
        • Sep 2005
        • 2076
        Thanks,
        Thanks for the replies:
        I will get started on parts when I hear back so I get the correct headgasket. I assume the rest are basic 323i gaskets....at least they look to be. Bet the crank bearing are not standard, or maybe they are just normal 2.7 bearings....
        thanks,
        jm
        • 2002jm
          • Sep 2005
          • 2076
          thin gasket
          I read that hartge used a thin gasket to up the compression??? So how would I know how thin?
          thanks,
          jm
