First post; stumbling under acceleration
  • dpmit94
    • May 2015
    • 88
    Greetings fellow members of R3v, my name's Doug. This is my first post so I apologize if it's in the wrong area, although I'm pretty sure I got it right. I've had my E30 for a while now, been lurking around these forums quite a bit and I admit, I've been lazy and haven't posted a single thing about my car until now. I guess a positive about the problem I'm having is it finally gave me a reason to get involved
    A little background on the motor itself just to help, I'd rather give more info than necessary than too little. Current mods to the engine include:
    Rebuilt head by a BMW specialist shop up in Vancouver; new OE rocker arms and valves
    Schrick performance cam
    Schrick valve springs
    Larger injectors (forgot the size, if relevant I can get it tomorrow when it's light out)
    Long tube headers and magnaflow exhaust
    Dinan chip
    Now on to the problem...
    A week ago she was running great apart from a slight idle fluctuation regardless of engine temp. A few days ago I noticed a very, and I mean very slight bucking while I was accelerating. It was most noticable in first and second gear, and I did notice a bit of hesitation between 2-3k rpm. For the past couple weeks my CEL has been on for my O2 sensor. Convinced this was the problem, I went to NAPA and ordered a Bosch O2 sensor and replaced that yesterday. However, on the way to the auto parts store, I noticed my car sounded different, almost as if it was only running on 5 cylinders. Also it was a bit louder, and had a very shaky acceleration like a continuous vibration from the engine. The bucking is gone, and now it just lacks power and seems to be running extremely rich; you can hear the fuel igniting from hitting the headers by a loud crack-like pop out of the exhaust (not like the normal downshift burbles of a tuned car ). Lastly, when idling if you pull the throttle to rev it, the motor stumbles and almost dies out for a quick second before it actually revs.
    Thinking it was all related to a faulty O2 sensor sending the wrong AFR's to the ECU I went ahead and replaced it hoping it would fix the problem. The check engine light is now gone, but the problem still exists. I am not throwing any codes as of tonight, which makes me think whatever the issue is is not monitored by a sensor although I could easily be wrong with this theory. At first I thought a vacuum leak, however I am now leaning more towards an ignition problem. I pulled a spark plug from cylinder 1 and cylinder 5 after work today to see how they looked and they were completely covered in a thick coat of carbon. Good news is it was not oil fouling and they were equally just as bad. I'm going to grab some new ones tomorrow and see how it runs. Also, there is no smell of gasoline under the hood while it is running.
    Other things I have checked:
    -Plugs on the injectors are tight and plugged in all the way
    -HT leads are all the way on, checked plugs, coil, and distributor.
    -All fuses that were even slightly relevant checked out okay
    -CPS is good, I've read it wouldn't even start otherwise
    Things I have yet to do (partly based on the answers I get here)
    -Compression test
    -New spark plugs
    -Inspect distributor
    -Check spark from each lead
    -Check fuel pressure, although I'm fairly certain it has nothing to do with fuel delivery
    -Clean ICV
    -Clean MAF
    -Test for any vacuum leaks
    -24v swap...
    I also was reading up tonight on the engine coolant temp sensor and it sounds like a possibility... would this match my symptoms?
    Am I on the right track? I don't want to spend time chasing a ghost. I need to get her running right since she's my daily here for a few months.
    Also, I can get a video tomorrow and post it so the issue can be heard first hand. And apologies for this unorganized mess of a post, I feel like I'm writing a paper for school and losing interest with every keystroke.
    Thanks!
    '88 325is. built M20. dd.
    '72 2002 roundie sold
    Instagram @doug_mitchell
  • dnguyen1963
    • Nov 2011
    • 2651
    Did you check the rotor? It is definitely fuel delivery issue. I would check for leaky injectors. When you changed for O2 sensor, did you reset the ECU? It does not hurt to do a smoke test, but I would concentrate on finding why you have too much unburnt fuel.
    • ahlem
      • 369
      Check valve clearance.
      • Gregs///M
        • Mar 2012
        • 2459
        If you are using the original AFM, and never had it refurbished, consider it bad. Bad AFM symptoms are sudden and brief power loss. Power quickly returns.
        Owner - Bavarian Restoration
        BMW and European Electronics Repair and Restoration
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        Follow our Instagram!
        • dpmit94
          • May 2015
          • 88
          I pulled all my spark plugs today and found the culprit. I was right thinking it was only running on 5 cylinders. Here is the plug from cylinder 6: http://imgur.com/HYUK5Yd
          I know I need to check valve clearance and adjust. My guess is oil is making it's way into the cylinder through the valves while it sits. My other thought was blown piston rings but no oil is burned while the motor's running. I'm going to adjust the valves then do a compression test to confirm. She's running beautifully for the time being!
          Also, how do I get the picture to show up in the post instead of linking to Imgur?
