M20 coolant flush...NO HEAT
  • 968Reckless
    • May 2013
    • 1095
    I'm going to flush the coolant with OEM blue because I have a small leak and don't just want to put more in because I don't know what's already in the system.
    My problem: I don't have heat in my e30.
    All the DIY's I've read say the heat needs to be turned on in order to bring everything up to temp to get air bubbles out.
    What are my options?????
    /// MTech Belts ///
    S52 BUILD
    M3 VERT BUILD
  • estoguy
    • May 2013
    • 1087
    So have you actually drained the system yet?
    But yes, you leave the heat on and turn your blower on, so you can feel the heat.. Make sure the front of the car is jacked up on stands, so that the bleeder is the highest point. Will help get the air bubbles out. While filling the system, also keep it open.
    Estoguy
    • 968Reckless
      • May 2013
      • 1095
      No the system is not drain....I don't have heat... The heater was removed...
      /// MTech Belts ///
      S52 BUILD
      M3 VERT BUILD
      • EatsHondas
        • Sep 2012
        • 404
        You can bleed the system without a heater core. Blasting the heat is only to give you confirmation of coolant circulating through the core. The blower motor being on or off makes no difference to the cooling system. If you had a heater core, all you would need to do is turn the temp selector to full heat. This opens the electronic heater core valve and lets in hot coolant from the engine.
        Jacking up the front of the car is REQUIRED. I have tried to bleed mine on the ground multiple times, and it's never worked.
        1989 325i Lachssilber Sedan
        5-Speed Swapped
        M30B35 Swapped
        MegaSquirt MS3X
        1987 325i Lachssilber Sedan
        260k OEM Automatic Daily Baby
        • vpilarrt
          • Jun 2006
          • 2096
          If the heater core was removed and the hoses re-plumbed you don't need to do anything different to bleed the system other than not having to turn on the heater.
          • 968Reckless
            • May 2013
            • 1095
            Perfect! And yes I'll have the car jacked up...
            /// MTech Belts ///
            S52 BUILD
            M3 VERT BUILD
