Hi. I have an 88 325ic with the M20. Been having a problem the past few weeks with an intermittent idle issue is the best way I can describe it. The car starts and runs fine. I recently put a new IACV, air intake boot and plugs into the car. The problem I'm having is that at various times the engine will seemingly cut out for a fraction of a second. This happens usually when I'm on the highway and start to accelerate a little, but also happens at idle. It's like the engine has a hiccup. Usually when this happens, the check engine light with flash on for an instant and then back off again. It doesn't seem to effect drivability or power. It has to be something in the engine management somewhere. It seems like an idle issue. I haven't yet swapped out the new IACV for the old one to see if that's the issue or not.
Any other suggestions?
Thanks.
Thanks.
