Hose off of waterpump keeps leaking
  • e3irsty
    • Jan 2014
    • 134
    With a new waterpump and waterpump to thermostat housing hose. I can't seem to get those to seal right even when clamped as tight as possible onto the pump. It seems like the notches in the water pump keep parts of the hose uneven. Not sure why they are even there. Anyone else have this problem? Seems simple to fix just can't get it right
    Sent from my LG-LS980 using Tapatalk
  • e30onBBSs
    • Dec 2014
    • 1347
    Have any pics?
    BMW tech
    Umass Amherst
    05 wrx sti
    • TobyB
      • 5286
      I had that happen with a moulded radiator fitting- turned out there was a line of casting
      flash that hadn't been cut off, and it was making a line for water to seep out. I finally
      pulled the rad to look for cracks, and saw the trail the water had been following on the inside
      of the hose. A little work with the mattknife, and it sealed up fine.
      I can see how that might happen with the casting lines on the waterpump nipple, too.
      BMW loves those ridges, but they sometimes make things worse...
      t
      • efficient
        • Feb 2012
        • 3312
        My hoses leak too could be cus I bought generic cheap brand hoses. Next time going full oem
        • goldenbb
          • Jun 2013
          • 208
          Check the housing itself--mine had a lot of scale built up on the aluminum and that made it hard to get the hose to seal tightly. Almost killed my engine when the hose popped off the first time I tried to drive it to work after the head gasket replacement. Kind of ruins your day.
          '90 zinno 325iS
          • e3irsty
            • Jan 2014
            • 134
            I actually blew my head gasket the first time due to wastegate failure and the compressed air from the cylinder went into my coolant jacket blowing the hose off from the water pump and my turbo sucked in so much coolant lol. I kept adjusting it and tightening the hell out of it now it doesn't leak. Thanks for the help!
