Super high idel in park
  • BlancoThirty
    • Jul 2015
    • 4
    I'm new to e30 life. Just picked up a 87 325 auto and in park and nuteral idel is super high and keeps raising then in park drops to normal. Also feels sluggish on the freeway. Any help is great.
    -BlancoThirty
  • dnguyen1963
    • Nov 2011
    • 2651
    Have a shop perform a smoke test for you.
    • ahlem
      • 369
      Check for vacuum leaks and any cracks in hoses, especially the big intake boot going to your throttle body. There are a couple metal press-in fittings that go into the throttle body that can be loose that need to be sealed up. Make sure your throttle cable and cruise control cable aren't too tight or have broken fittings. Check the electrical connections at the coolant temperature sensor and check it's function with an ohmmeter and instructions from the Bentley manual.
      • BlancoThirty
        • Jul 2015
        • 4
        It also accelerates to about 15 on it own in drive but Rpm is normal ? any ideas?
        • e30onBBSs
          • Dec 2014
          • 1347
          Yea definitely check the cables/ guides. One time mine was broken and had similar symptoms, but mine's a manual. This little clip was broken and made it rev by itself.
          BMW tech
          Umass Amherst
          05 wrx sti
