Engine Speed Sensor Question
  • betsy325e
    • Jun 2015
    • 81
    Whazza, driving enthusiasts/gluttons for punishment?
    Still trying to track down high idle. I noticed that the connector on my Engine Speed Sensor is absolutely destroyed. From what I understand it counts teeth on the flywheel by magical magnetic somethin' or other. I understand that that information is then sent to the ECU and the idle control module. Did the ohm test: 960 +/- whatever. Seemed fine.
    My question is, what does this engine speed sensor actually do, and, when operating normally, what is it telling my ECU/ICM to do?
    Thanks.
    J
    The reference to an ICM makes me think that this is a E car. In which case both the transmission mounted speed and timing reference sensors are probably overdue for replacement. There is a front mounted speed sensor, but it is only fordiagnostic purposes.
    The purpose of those sensors it to tell the DME/ICU what the engine speed and timing are in order to control spark & fuel. In most cases a high idle will be due to intake leaks or a bad ICM. Have a smoke test run.
    • betsy325e
      • Jun 2015
      • 81
      Jlevie,
      1987 325e.
      I asked because I remember reading something somewhere about the speed sensor failing causing the car to go into some sort of "limp" mode. This morning I had my #3 and #4 fuel injectors miswired. Rectified the situation and still ran exactly the same. Made me wonder if the car is in that "limp mode." I don't even know if such a thing exists. Just spit balling (getting desperate as you can see from this thread):
      Have you ever heard of such a limp mode setting being caused by a failing speed sensor?
      Thanks,
      J.
      • TobyB
        • 5297
        The e senses engine position/speed from 2 sensors in the bellhousing, reading off
        cuts in the flywheel.
        the sensor in front is just for diagnostics, and isn't used by the ECU on the eta...
        t
