Help with afpr!
  • 3URO_BOY
    • Feb 2012
    • 183
    Help with afpr!
    So im trying to figure out what to adjust my bev auto adjustable fuel pressure regulator to. I have an 87' 325is 2.5l, with performance chip, 19lb injectors yellow top mustang, walbro fuel pump, performance headers, k&n box filter, magnaflow performance cat, and will most likely put the m30 afm, and the bev auto performance adjustable fuel pressure regulator. I know stock fuel pressure regulator runs at 38-39psi.
    Stock fuel pressure is about 37psi at idle and 44psi off idle. With the changes you've made to the engine, you need time on a dyno with a wide band sensor to tune the engine for best operation.
    • digger
      • Nov 2005
      • 6194
      i would have just when to Squid and got a chip from him that way you dont need a AFPR.
      • 3URO_BOY
        • Feb 2012
        • 183
        Ok i guess ill try that out thanks. Dyno it is!
