M20 Manuel Radiator 550MM Size
  • sedattemur
    • Jun 2013
    • 30
    Hello guys. I looking m20 manuel raditor for my car. My country is very hot for cooling system. My engine very very warming. I want chance my raditor. My radiator size 450mm small size. I looking 550MM size big radiator for my car. Please pm and help to me.
    • 34839
    get a Z3M S54 radiator. It will fit in the E30 directly and is a 3 core design, not terribly expensive either. I'm not sure if there's enough clearance for the clutch fan, but you could always convert to electric if necessary.
    This also assumes you have the later cooling system with the expansion tank on the left side of the car. If you have an early car, you'd have to do a conversion so the inlets are on the right sides.
    Other things to consider instead of the radiator is changing the thermostat to maybe a 70c version and making sure the waterpump is functioning correctly. also, a broken fan clutch will cause the engine to overheat even if you had a bigger radiator.
    • sedattemur
      • Jun 2013
      • 30
      I did my car engine is rebuilded one mounth ago but fan is cracked. Then chance my fan so I see my radiator is small - Looked another forums they are says mashimito and pwr radiator. I don't know which one best for me ? . My country only hot local. +25 / +37c hot.
        • 34839
        Z3M S54. I already told you. :p
        Mishimoto I wouldn't touch with a ten foot pole. Unless you want a radiator you have to replace every 6 months due to leaks.
