E30 Stroker - The why.
  • FunkySwerve
    • Feb 2015
    • 43
    I've looked up many threads online about this very topic, perhaps I've missed a post in the many many pages of Stroker science and math...but there doesn't seem to be a short answer as to why you would stroke your engine in the first place.
    So why stroke a m20B25 engine? Advantages? Disadvantages? I understand this may lean more towards subjectivity, but it'd be nice to know any and all reasons.
    Also...because I live in CA, is it CA smog compliant and street-able?
  • biodose
    • Jun 2015
    • 145
    I've always been told that there's no replacement for displacement. Stroking = more displacement = more torque. People mainly do the 2.7i for the turbo application because it lowers the cr from 8.8 to 8.5:1. Not sure if that's what you're looking for, but hope it helps.
    Support my E30 addiction! Buy my Wideband/Voltmeter Check Panels
    HERE
    1990 Flachalpinweiß 335i
    • FunkySwerve
      • Feb 2015
      • 43
      That does help, thank you! It makes a lot of sense given how light it is(and can be) and of course the rear wheel drive!
      • Hooffenstein HD
        • Nov 2012
        • 1388
        Why? Increased displacement.
        • digger
          • Nov 2005
          • 6213
          Stroking an engine provides a means to increase mass flow of air through the engine
          When you move more air through the engine and add a corresponding amount more fuel and it is burnt efficiently you get more power
          the advantage of stroking the engine is that the mass flow has the potential to be increased at all rpm, though more typically the lower end and midrange torque and power show the biggest gains and the top end less gains but it depends.
          • FunkySwerve
            • Feb 2015
            • 43
            Well that answers my street-able question. Will it past inspection? =0
            • wilholl
              • May 2012
              • 518
              generally there are no visible indicators on the outside of the engine to determine if the displacement has been increased. So, visually it should pass.
              As long as the engine is running well with the proper air/fuel ratio then it should pass the tail pipe emission.
              1988 325 non-letter Seta "Bronzit"
              1991 325ic "Laguna Green" (Sold)
              1993 325i "Laguna Green/Silver" (Sold)
              1998 528i "Artic Silver" m-sport(totalled by drunk driver)
              2000 528i Titansilber/gray m-sport
              2000 528i Titansilber/black m-sport(sold)
              2001 525i Anthracite m-sport(sold)
              2013 750i Black/Black m-sport "Beast"
              • FunkySwerve
                • Feb 2015
                • 43
                Excellent! I've read a lot of things need to be bought new and customized to some extent. I reckon it's quite expensive just on parts alone?
                • Hooffenstein HD
                  • Nov 2012
                  • 1388
                  It can be pretty much as simple as a head gasket replacement, or a full race build. Depends on the size of your wallet and goals for the car.
                  • digger
                    • Nov 2005
                    • 6213
                    yeah budget stroker are cheap, expensive strokers are expensive
                    • KIRIEIW
                      • Dec 2012
                      • 3385
                      For what its worth, I engine swapped my car from a M20B27 to M20B25. The smog stations here in CA smog it as a B27 and I've never had an issue, always passed with flying colors. It's been smoged 3 times now.
                      1992 e34 Touring- S50 Swap
                      1992 325i-S50 Swap (SOLD)
                      1991
                      • FunkySwerve
                        • Feb 2015
                        • 43
                        What's the median cost on the low end and the high end?
                        How much work may you do yourself and what are the things best left to professionals?
                        • digger
                          • Nov 2005
                          • 6213
                          how long is a piece of string? you can do it for free or spend 15k and anywhere in between
                          the important question you need to answer is how much do you want to spend?
                          what skills do you have?
                          and what are your goals?
                          • FunkySwerve
                            • Feb 2015
                            • 43
                            I'm willing to spend North of 5k.
                            I have a basic understanding of most everything about a car. I would say I have an above average understanding of E30s. My wrenching experience is average DIY'er at best, so I have most tools to take things apart, one way or another...and I also have good knowledge on how to put it back together p-r-o-p-e-r-l-y.
                            My goals in terms of power? Exactly what stroking suggests: lots of low end torque so I can take off from a stop or put my foot down(safely) on a straight road while driving to work at 4 in the morning. BHP is merely a factor in the equation for me, but I understand I can expect a little over 200BHP with just a stroker build on it's own? Just want a fun daily driver, with more emphasis on fun rather than daily driving. ;D
                            ***When I take a minute to think up more questions, perhaps we can open up this thread to questions about stroking that may not be easy to find on a google search because it's so specific or uncommon!
                            • Hooffenstein HD
                              • Nov 2012
                              • 1388
                              5k spent wisely with you doing a majority of the wrenching should be able to get you 200-220rwhp.
                              I don't think a 5k build aligns with your goals though. You could get away with a basic build and half the dollars invested.
