E30 m20 starting problem
    ok :-) while i was searching on the web for a possible cause of my problem i found something about shims? what are those?
      Shims are usually to make the starter align properly. I don't think m20's use them. I'm not 100% on this though. My m20 doesn't use any shims, and I haven't seen one that does.
      Originally posted by Andy.B
      I was born on 3/25…
        Ok tnx :-)
          got the other starter in the mail today. Then i figured out i need a pre facelift starter and this one is a facelift version. My car is a one of the first facelifts cars (12/87) and uses some components of the pre facelift..
          it looks exactly the same but the bendix is slightly larger and when i installed it it would spin against the flywheel and not engage it..
          atleast i know now that the starter is the problem..
          can you switch the bendixes on these starters? or i'm i going to look for another pre facelift starter
            Or can i just switch the solenoids on top of starter?
            OLd starter: 1005 821 086 (1/01)
            New one : 1005 821 086 (1/02)
              Give it a try, it may work.
              I was born on 3/25…
                bam! Switched the solenoids and she started right up!
                Topic can be closed! Tnx for the help
                  Werd.
                  I was born on 3/25…
