is there a way to feed the CPS (crank position sensor) w/o removing belts/hoses?
  • audiquattrot
    • May 2008
    • 3836
    I'm about tor replace it, and it doesn't seem like there is room to either get the old sensor out (which I plan on cutting), and feeding the new one in.
    If there is enough slack in the wire, I may just temporarily route it above the engine for the meantime.
    Does anyone have insight if this can be done w/o removing a ton of stuff?
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
  • betsy325e
    • Jun 2015
    • 81
    Doesn't look that bad. Can you get at it from underneath?
      • 34839
      I've done it. it's a pain in the ass. most likely, you will break the clips that hold the CPS wire cover that snaps onto the timing belt cover. I'd get new clips ahead of time, you don't want to leave that cover off.
      you can put it back together correctly as well, but it sucks. you can try removing the bypass tube bolts to give you enough room to pass the new sensor through. I wouldn't route it a different way, it's likely to rub on a pulley or something else and fray, which will ruin the sensor you just put in.
      I'd consider draining the coolant into a clean bucket, and just getting the bypass tube and belts out of your way. it'll be so much easier.
        Assuming the cover for wires is present and in good shape, it is possible to get the cover off and route the CPS in the correct manner without removing anything else. Possible, but difficult. An easy alternative is to route the wire over the valve cover. You can fix that later on the next water pump change (every 100k).
        • audiquattrot
          • May 2008
          • 3836
          Thanks guys. For right now I snaked the wire underneath some coolant hoses along the metal rail and zip tied everything out of the way. Unfortunately the cps didn't correct my no start issue.
          I even swapped the main relay, fuel pump and O2 relays w my buddies ix, but nothing. I pUt in new spark plugs since the 6 month old ones were looking pretty beat up, and she still cranks but no start
          Ran out of daylight, so I'm going to properly check for spark this wkend when I have time....
          I wonder if unplugging the ecu for a given amount of time will help. Another local ix'r had a similar issue, and was able to correct his problem after leaving his ecu disconnected for a couple days
          In other news I've been DDing my e46 m3 and cracked my windshield from my highway commute. :down:
          #snwmble
          Current:
          Past:
          • Reichart12
            • Aug 2012
            • 2163
            Did you make sure you have the cps close enough within spec? The bracket can be bolted up normally but before being tightened it will have some wiggle room so the sensor might be too far away from the gears to read.
            Instagram: Reichart12
              • 34839
              the power to the volatile memory runs out in about 5 minutes.. and it doesn't store a whole lot. there's no reason to leave it unplugged for a couple days.
              • audiquattrot
                • May 2008
                • 3836
                I'll try loosening it and readjusting this wkend. Thanks for the tip!
                I'll try unplugging for a bit and reconnect. I'm not sure if it will make much difference though in starting the car. Would a stomp test tell me anything if there was never a fault code/CEL on the dash?
                #snwmble
                Current:
                Past:
                  • 34839
                  probably not
                    The spec is a 1mm gap.
                    • e30onBBSs
                      • Dec 2014
                      • 1347
                      I did the same thing with zip ties, after ripping through the one I put back lazily. It's been good so far.
                      What happens when you turn the key?
                      BMW tech
                      Umass Amherst
                      05 wrx sti
                      • audiquattrot
                        • May 2008
                        • 3836
                        No spark. Swapped coil, ecu, afm and still nothing. I'm gonna check voltage tomorrow. Anything else to look for?
                        #snwmble
                        Current:
                        Past:
                        • audiquattrot
                          • May 2008
                          • 3836
                          Mixed up the harness plugs the cps is supposed to plug into w another one (spark plug wire). Swapped the two and she started right up!
                          #snwmble
                          Current:
                          Past:
                          • Reichart12
                            • Aug 2012
                            • 2163
                            Awesome! Glad to hear your car is back to running.
                            • audiquattrot
                              • May 2008
                              • 3836
                              Thanks buddy! Got a couple more things to fix but she's back on the road
                              #snwmble
                              Current:
                              Past:
