Replacing M20B20 L-Jet with newer and better injectors(With link)
  • Raja_Mongkut
    • Aug 2012
    • 75
    Was researching on injectors for my L-jet system when i stumbled upon the link below.
    https://www.drive2.ru/l/288230376152672864/
    What's interesting was that the dude replaced the 30 year bosch injectors(that share the same p/n as the M20B20 L-jet injectors) with newer injectors that were similarly spec'ed.
    Original Injectors:
    Bosch 0280150208 133ss \ min, 3bar, 16Om.
    Replacement Injectors:
    Bosch 0280158502 132ss \ min, 3bar, 12Om.
    Note that while they are both high impedance, the new injectors still have lower impedance than the original.
    Considering how tired and scarce L-jet injectors are getting, would this be a worthwhile upgrade? Judging from the pintle design it should have better atomisation too.
  • Coyote_ar
    • Sep 2009
    • 175
    those look like EV6 injectos, but with a EV1 connector. the length is the same, so they should be a direct replacement. as you said, they have better atomisation than the old EV1s.
    ---E30 320i Hennarot 1984 Sedan---
    • Raja_Mongkut
      • Aug 2012
      • 75
      Great! Should I be bothered by the 4 ohm impedance difference?
      • Coyote_ar
        • Sep 2009
        • 175
        dont think so, low impedance injectors are like, 3-4ohm. so those are still high impedance. its likely they are more efficient than the old EV1s, hence the lower impedance.
        • Raja_Mongkut
          • Aug 2012
          • 75
          Great! I'll see if I can get a set and post back on my findings...
          • SpecM
            • Oct 2005
            • 4531
            Any idea about newer injectors for a Motronic 1.1/1.3 system for an b25?
            Sent from my SM-G900V using Tapatalk
            1989 cirrisblau-metallic 325i
            • TobyB
              • 5296
              I dunno- I KNOW they're Bosch, but putting anythink Lada in any kar I drove vould make
              me a bit nervous...
              hee
              t
              • Raja_Mongkut
                • Aug 2012
                • 75
                me a bit nervous...
                hee
                t
                Haha! Do they really have that bad of a rep?
                • Raja_Mongkut
                  • Aug 2012
                  • 75
                  Options should b aplenty for low impedance EV1 injectors used in Motronic systems, it's us L-Jet guys that have it hard
