Cyl #4 70psi compression - ut oh
  • 3rdtimearound
    • Jul 2015
    • 19
    So I did a compression check on all cylinders after I bought the car rather than before. Smart right? Anyway all checked out above 150psi and in spec except for number four which was at 70psi. I then did a wet check where I added oil to the cylinder and it jumped to 210psi.
    So this means rings right? Any chance it is just a head gasket? And what are my next steps? Do I need to do a leak down test or is this conclusive enough?
    Assuming it is the rings is there a way to fix this cylinder without pulling the engine? Like push out just this cylinder with engine in the car?
    Thoughts?
    Current BMW's:
    1987 325 Sedan
    2004 X3 2.5i (wife's car)
    Ex BMW's:
    1999 M3 Coupe
    1997 Z3 2.8
    1989 325i Coupe
    1987 325 Coupe
    1981 320i Coupe
  • TobyB
    • 5298
    Just bought it? drive it a bit. It may have sat with #4 open, and have rust in it.
    And don't panic immediately- while 70 isn't great, it's not a dead engine yet. Even
    if something's wrong, you have time to find a replacement.
    The #210 test confuses me a bit- usually with weak rings, oil boosts the number,
    but not ABOVE the others- normal 'bad ring' numbers would see it jump from
    70 to maybe 110 or something like that.
    I'd investigate further- and keep driving it. Maybe a borescope, if you can find one to
    borrow, or have a mechanic friend take a look?
    Personally, I'd do a leakdown too, because it's cheap and easy. But I broke down and
    bought a tester years ago...
    hth
    t
    • 3rdtimearound
      • Jul 2015
      • 19
      Some of the other cylinders hit 185-190 so the 210 isn't far off. Leakdown would be nice if I had the equipment.
      Also I put 1000 miles on before testing it.
      Current BMW's:
      1987 325 Sedan
      Ex BMW's:
      1999 M3 Coupe
      1997 Z3 2.8
      1989 325i Coupe
      1987 325 Coupe
      1981 320i Coupe
