TPS WOT switch repair
  • Som
    • Jan 2014
    • 126
    Didn't really see this anywhere else so I figured I'd post it. Usually the discussion is about replacing the idle switch in the TPS and not fixing the WOT switch. Anyways, it's not exactly hard to figure out once you crack the TPS open, but figured I'd post how I repaired the WOT switch in my TPS.
    The main symptom that led me to check the TPS was a noticeable loss of power at WOT above roughly 4500RPM. Still pulled to redline, but noticeably bogged. I have yet to reassemble/retest, so it's possible there are other root problems in my case, but the TPS WOT signal was definitely something that was failing.
    For reliability it was recommended to just buy a new TPS -- which I've done and agree is the reliable way to go. When buying a spare one, I was told by the parts guy at the dealership that there are exactly 3 of these left (now 2) in the US and NLA from Germany. I'm guessing you can still buy the Bosch or FACET versions, though. The Bosch ones (which usually sell for $50-75) are all out of stock in the places I've looked online. The only ones I found available were the FACET one or the Genuine BMW one -- the latter selling for $100-150.
    Once I bought one, I figured I'd take a look inside mine and see if the fix for my missing WOT signal would be obvious/easy. In my case, 80% of the time I did a continuity test with my DMM, I'd get a fail. Occasionally, though, it would pass.
    After opening it up, the 2 points where the flex-arms connected to the pinouts had a cracked solder connection. I separated the pinout connector from the arm a little more and soldered the two together. The photo is from after I separated the two -- before that it wasn't obvious the two weren't connected.
    Make sure to avoid a cold solder by heating up the pinout connector / arm (I used a flat-tip soldering iron) and letting the solder flow through direct contact with those pieces, rather than making contact with the soldering iron tip. Also note that, arguably, the better way to do this is to use needle nose pliers to pinch the pieces together and reheat the connector to get the original solder to reflow. Might be a cleaner approach (maybe even add some new solder to the mix).
    Also, I applied some excess solder to help keep the connection together.
    The fix resulted in my WOT signal working. Now I'm just hoping that this resolves my high-RPM bogging problem. :)
    Som
  • EatsHondas
    • Sep 2012
    • 404
    Results?
    1989 325i Lachssilber Sedan
    5-Speed Swapped
    M30B35 Swapped
    MegaSquirt MS3X
    1987 325i Lachssilber Sedan
    260k OEM Automatic Daily Baby
    • Som
      • Jan 2014
      • 126
      Just fixed it last night. The immediate result is that my WOT signal consistently turns on when I open the TB up near WOT.
      I haven't reassembled to determine if my particular issue was resolved by it, but it definitely fixes one problem.
      Som
      • goldenbb
        • Jun 2013
        • 208
        Can someone link to any discussion about replacing the idle switch? I searched and came up with nothing.
        ETA: I mean the little switch inside the main unit, not the whole unit itself. It looks like a momentary switch and I bet something similar could replace it without too much trouble.
        '90 zinno 325iS
        • Som
          • Jan 2014
          • 126
          If I run into the thread again, I'll post it. Unfortunately, I don't know where I saw it and a simple search didn't bring it up, either. :(
          But there's one or two out there. :)
          Som
