headgasket job problems
  • E30_Packin
    • Aug 2015
    • 3
    Hello all, first time posting as i can't seem to find anything about this. I was doing a headgasket and everything was going smoothly up until it was time to toque the head bolts. i was using new bmw torx style head bolt and following the torque guide going 22-90-90 in the proper order. After torquing them to 22 foot-pounds i moved onto 90. The first bolt i go to tighten doesn't seem to go past 60 foot pounds. my question is, what the hell is going on? The threads look fine. I am using new head bolts and washers so i dont know what it is. Any advice is much appreciated
  • Andy.B
    • Sep 2011
    • 1650
    You don't torque it to 90 ft/lbs. You tighten all bolts to 22 ft/lbs, then rotate each one 90 degrees tighter, then another 90 degrees.
    If you've gone past that, or don't know what you did, I would seriously consider a new head gasket and bolts, and try again, because it's cheaper to be cautious now then destroy the threads in the block, crack the head, or find out you ruined the gasket by over tightening one bolt.
    • E30_Packin
      • Aug 2015
      • 3
      Well Fuck....
      • Andy.B
        • Sep 2011
        • 1650
        Sorry man. We've all made mistakes when wrenching. I once replaced a transmission on a range rover, and didn't clock the flywheel correctly on the crankshaft. Then I couldn't figure out why it wouldn't start. That was an extra 10+ hours of work I didn't get paid for, and man did I feel like an idiot.
        • E30_Packin
          • Aug 2015
          • 3
          Yikes, that's awful. Well I guess I'll get some new head bolts and gasket. Thanks for clearing that up.
          • e30onBBSs
            • Dec 2014
            • 1347
            +1, this is probably a common mistake? Just learned about it in school
            BMW tech
            Umass Amherst
            05 wrx sti
            • whodwho
              • Jun 2008
              • 1547
              I wouldn't change the gasket, just change the bolts out one a time torque to the 22lbs and then proceed to the next torque steps in proper sequence.
              You should make sure there are no fluids in the bolt holes by blowing them out before inserting new bolts.
              My M20 Frankenbuild(s)
              4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
              • SilverShadowH27
                • Mar 2014
                • 6
                Oil the bolts to help with torque and 90 degrees turn!
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  You also want to put some oil on the face of the washer where they contact the head. This prevents friction from effecting your torque readings.
                  Alice the Time Capsule
                  • mtnbimmer
                    • May 2012
                    • 73
                    Why wouldn't you? The original bolts have been overtorqued which means the head gasket has likely been compressed too much. Seems like cheap insurance to change it now versus having to completely tear down the engine later.
                    • spdracrm3
                      • Sep 2009
                      • 959
                      torque to yield bolts will NOT overtorque hence the name....they just keep stretching at yield point till they fracture
                      gasket will be fine
                      Angus
                      88 E30M3 X2
                      89 325IX
                      92 R100GS/PD
