vaccum valve for heater core - delete?
  • funcrew
    • Jun 2007
    • 1223
    1991 m20b25. There's a vacuum activated valve in my heater core hose rat's nest. Can I just bypass this and seal off the vacuum connection near the brake booster? What was the purpose?
    I found the M42 cleaning up the mess under the intake thread. Couldn't find an equivalent for the M20. Is it mostly the same?
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • reelizmpro
    • 9559
    I don't recall there being vacuum to the valve are you sure? That's the coolant thermostat BMW added when they did recall 93v-015 to keep boiling hot coolant from reaching the core when the car overheats, potentially leaking and burning the driver in the process. There was a lawsuit over this. I still have the letter from BMW from the early 90's. I would not delete it. The only "con" of this mod is that you can't use the heater core/blower as a radiator to cool your overheating engine by turning on full Heat. BMW doesn't want you to do this.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
