Das Beast: My E30 track / street build
  • dvallis
    • Oct 2015
    • 1474
    #136
    Engine disassembly
    Time to break down the M20. We got this done in one evening after work. It's actually not too bad. Our method was bag, tag and label the crap out of everything. Takes a bit longer but will make re-assembly a whole lot easier.
    Valve cover comes off no problem. Just a few bolts. Don't forget to remove the bracket on top.
    Top of head looks pretty good. Nothing bent or broken. Just nasty with 30 years of not being cleaned.
    Water pump. 30 year old rotating assembly with rubber inside. This gets replaced. :devil:
    Timing belt was in surprisingly good shape. Still gets replaced though. I love the simplicity of the M20. You can see exactly how everything works.
    Another view of the 885 head. This will definitely get hot tanked. I am going to port and polish this myself.
    Block deck with gasket. Head was not tight and oil was leaking. Pistons have nasty carbon buildup. Will hand clean them in a parts washer and tank the entire block.
    These are weird little widgets. Rocker shaft oil seals. You can see where someone tried to seal them with goop. Anyone know if there's an aftermarket version of these in metal? They look like a weak point.
    Minor goof. Had to get the block back on the floor and take off crank oil seal on flywheel side.
    Pistons and rods pulled. Boy they are nasty.
    Block completely disassembled. You can seen the floor through it. :devil:
    Here's the money shot. M52TUB28 crank sitting nicely in the M20 block. It fits GREAT. Turns smooth with no interference at all.
    Entire M20 bagged and tagged, minus the block, oil pan and intake manifold.
    Finally, here are a couple of WTF pictures. If anyone can identify these two things please post here or PM me:
    What the heck is this??
    What does this inlet or outlet cool? (Tube looking thing on the back of the block) It routes to either the thermostat valve or water pump. Is it required?
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
    • berlow94
      • Jan 2013
      • 1063
      #137
      The long pokey thing is your oil pressure relief valve.
      The coolant tube on the back of the head goes to your heater core if i'm not mistaken.
      The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
      • zwill23
        • Jul 2015
        • 615
        #138
        Heatercore to Head - Coolant Spout
        Yep. Berlow94 is correct, that spout on the back of the head provides coolant from the heatercore to the back of the head. In specE30 it is common to use a block off plate here since the heatercore is typically removed, and it doesn't seem to cause overheating issues!
        Also, thanks for the exhaust! ;)
        • dvallis
          • Oct 2015
          • 1474
          #139
          Hey Zach, thanks for the info. You mean back of the block, not the head, right?
          BTW how much does that stock exhaust weigh?
          2002 E39 M5
          • zwill23
            • Jul 2015
            • 615
            #140
            Re: Head to Heatercore Spout
            Thinking about it, I actually misstyped. When I replaced my cylinder head, I completely forgot to add that little spout (big mistake on my part), so when I filled the engine with coolant it leaked right out of the back of the head.
            From my understanding, coolant flows from the water pump -> Block -> Up to the head -> Thermostat -> Radiator
            So that spout would actually be supplying coolant to the heatercore from the back of the head, but it flows through the block first.
            I am out of the house currently, I'll weigh them when I get home tonight!
            • 2mAn
              Señior Mod
              • 21031
              #141
              Nope, thats the back of the head, and yes it goes to the heater core. fuhraze means block it off.
              exhaust is somewhere around 100#. someone else has also made a list of E30 parts' weights. you can compare your weights with theirs to see how accurate the other stuff on the list is
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              Make R3V Great Again -2020
              • dvallis
                • Oct 2015
                • 1474
                #142
                Ha. There was so much grime on my head it looked like part of the block in the photo. :devil: Hot tank time.
                When I deleted the heater core, two hoses from it got plugged. One went to the back of the head (above). Where did the other one go? It was short so had to be back or side of the block.
                2002 E39 M5
                • dvallis
                  • Oct 2015
                  • 1474
                  #143
                  Zach weighed the stock exhaust complete. 68 lbs
                  2002 E39 M5
                  • dvallis
                    • Oct 2015
                    • 1474
                    #144
                    The Intermediate Shaft Bearing Blues
                    Cue an appropriately morose blue song. This is the Intermediate Shaft Bearing Blues.
                    Was doing some research on hot tanking an M20 block and found out the process will eat our intermediate shaft bearings. Apparently replacing them is a PITA, since they have to be machined in place once in the block. Should be no trouble for a competent machine shop. Here's an example of the bearing from another post.
                    For anyone else doing a hot tank on your block, here are resources on intermediate shaft bearing part numbers, removal and replacement
                    Thread 1 (Bimmerforums)
                    Thread 2 (R3VLimited)
                    Thread 3 (E30 Performance)
                    Thread 4 (Bimmerforums)
                    I found both bearings at eEuroParts.com (no affiliation)
                    11111280863 $20.99
                    11111264196 $6.24
                    2002 E39 M5
                    • dvallis
                      • Oct 2015
                      • 1474
                      #145
                      You guys should appreciate this info. Basic M20 rebuild kit list. Does not include potential upgrades like rockers, valve springs, piston rings, studs. Rod and crank bearings need to be looked at as well.
                      Top end gasket kit BMW 11 12 9 059 240
                      Bottom end gasket kit BMW 11 11 1 730 875
                      Timing belt BMW 11 31 1 711 081
                      Intermediate shaft bearing (f) BMW 11 11 1 264 196
                      Intermediate shaft bearing (r) BMW 11 11 1 280 863
                      Freeze plugs BMW 11 11 1 714 712 (x11)
                      Water pump BMW 11 51 9 071 561
                      Valve stem seal kit BMW 11 34 9 059 172
                      Throttle body gasket BMW 13 54 1 289 576
                      Oil filter BMW 11 42 1 707 779
                      Fuel filter BMW 13 32 1 268 231
                      2002 E39 M5
                      • dvallis
                        • Oct 2015
                        • 1474
                        #146
                        Hot Tank Ttime Machine
                        Getting the engine ready to hot tank tonight. First thing, intermediate shaft removal. Looks Ok, especially the bearing surfaces.
                        Ah, the infamous intermediate shaft bearings. Tried to pull them and failed miserably. Note my tool marks. Will check with the hot tank machine shop about pulling them. I have a set on order.
                        Oil dipstick tube came out easily. Just carefully clamp a set of vice grips onto it, twist and pull.
                        Water temperature (?) sensor removal
                        Water drain plug removal
                        Now .. the frigging freeze plugs. Here is my first attempt at pulling one. Used a drift punch to make a small hole, then inserted a J-hook made from a nail. It was an abject failure. Would you believe the frigging things take 600 ft-lbs to pull. Ugh.
                        Nothing can resist the Big Frigging Pipe. 2000 ft-lbs of goodness. Cut a slot in each freeze plug using a hardened chisel, insert crowbar, apply BFP and plugs pop right out.
                        One side of the block done
                        Other side done
                        One block ready for hot tank
                        Don't forget the miscellaneous block bits for the hot tank
                        Retaining clip to get the rocker shafts out
                        Rockers and rocker shafts out
                        Had to stop at this point as my Auto Zone rental valve spring compression tool was crap.
                        I need to get one of these (Craftsman)
                        2002 E39 M5
                        • zwill23
                          • Jul 2015
                          • 615
                          #147
                          Nice work!
                          Took some time to read your thread - so far the build has been very impressive, especially the electrical work you've done!
                          If you ever need an extra set of hands I would be happy to lend them, it seems I have much to learn!
                          P.S. Exhaust goes in tomorrow, and my E30 is getting inspected Monday!
                          • dvallis
                            • Oct 2015
                            • 1474
                            #148
                            Thanks Zach. Sent a PM to get your cell # again. Will give you a call when we start more work.
                            2002 E39 M5
                            • dvallis
                              • Oct 2015
                              • 1474
                              #149
                              Smash And Grab
                              Life got in the way of my E30 build. Was on business in Houston when thieves did a smash and grab on our SUV. They grabbed two computer bags, one of which was mine. Ugh. And I usually never, ever, leave my computer bag in the car. Just this one time for 45 minutes ........
                              Luckily everything is backed up and Das Beast photos are in the Cloud.
                              2002 E39 M5
                              • dvallis
                                • Oct 2015
                                • 1474
                                #150
                                Valve O Rama
                                Getting down to the last bits before going to the Hot Tank. Pulling valves & springs from the head. This is a proper valve spring compression tool. $30 at Sears.
                                Step 1: Compress valve spring
                                Pin goes against the valve head.
                                Forks go against the valve spring. use a magnet to remove the two retaining collets on each valve stem.
                                All done. Bag and tag with the associated rocker arms. Don't forget to pull the valve stem rubber seals. Throw away and replace with new ones.
                                2002 E39 M5
